I have a an app with two mobile views, an intro view and a map view. When I load the the Map View first everything works fine: http://jsfiddle.net/7bzMG/ But the idea of having an intro view is that this should be the first to load, but when this happens the map canvas doesn't size properly: http://jsfiddle.net/bHcDm// The only difference between the two fiddle's is in the first one I force the Map View to load first.
Does anyone know why this happens? It isn't the first time that I have this problem. The same happened using Tab containers. If the first tab to load isn't the one that contains the map, the map canvas doesn't size properly. The way I got around this was to add a loading overlay and once the application was loaded switch to the intro tab.
