I've created a slider (not a time slider) within my application and was wondering if it was possible to label the thumb. I used this Esri sandbox example to create the slider. In the Esri example, I would want to label the thumb with the selected population number. Is this even possible?
Thanks in advance!
If I understand the question correctly you can add a label to the slider thumb by setting labelsVisible to true:
const populationSlider = new Slider({
container: "population-slider",
min: 0,
max: 1000000,
values: [selectedPopulation],
labelsVisible:true,
steps: 10000,
snapOnClickEnabled: false
min: 0,
max: 1000000,
labelsVisible:true,
steps: 10000,
Thanks Kelly! I must have overlooked the labelsVisible setting.
