JS API: how to get a feature layer to rotate through which feature is on top?
641
07-07-2020 12:26 PM
JamesMcClellan
So, I'm building an app using the JavaScript API.  I have a feature layer that uses an unique value renderer in order to display custom symbols.  It's very common for a number of features to have the same exact lat/lon, and with the symbols being the same size, you can only see one feature.  When you click a feature the popup displays and you can page through and see the properties of all the features, but the visible feature doesn't change.  I want to be able to change which feature is being displayed to the user as they cycle through the features in the popup.  Any idea how to do this?
VictorTey
Hi, although I do not know the exact answer to your question, I can think of a workaround. you can create another graphic layer that dynamically generate a graphic to "overlay" at the top of the feature cluster. that way when you page through the features, you can just update the overlay graphic.
