I'm referencing a portal item map built in ArcEnterprise and I'm trying to set up layer searching. I've configured the layer search settings in the portal map settings as seen here:
The only layer that returns the search suggestions panel in my JS 4.11 app is the 'SC DOT Projects' layer:
All of the other layers should also return suggestions, as they each have a feature with an 'r' in them, but it doesn't work and I'm not sure what I'm doing wrong. Technically the search works for the layers, as it will search if I select the dropdown arrow, select the individual search layer, and then hit enter but no search suggestions will display which makes it hard for a user to properly search. The 'SC DOT Projects' map service isn't a service that I've published, SC DOT did, so maybe something is wrong with my map service settings?
Thanks y'all,
-Justin
