Javascript API - applying tooltips
6680
11-10-2014 06:27 AM
OliviaGill
At the moment I have 3 menu items that draw a line, point or area on a map. I'm using
  esri.bundle.toolbars.draw.addPoint = "Click the map at the location you want to search";
as a tooltip for drawing the point.
However for the draw area and line I want a different tooltip for each so that it reads:
"Click to start drawing a search line" for a line and "Click to start drawing a search area"; for an area.
At the moment this is the code that's used so that the line tool tip reads as area. Is there a way to distinguish between the two?
  esri.bundle.toolbars.draw.start = "Click to start drawing a search area";
  esri.bundle.toolbars.draw.resume = "Click to continue drawing your search area";
  esri.bundle.toolbars.draw.finish = "Click to continue drawing or Double-click to finish";
  esri.bundle.toolbars.draw.complete = "Click to continue drawing or Double-click to finish";
  esri.bundle.widgets.legend.NLS_noLegend = "Legend will appear here when search results are displayed on the map.";
  map = new esri.Map("map", {
  logo : false
Any help appreciated!
TimWitt2
Olivia,
Maybe you could create a custom window, if there is no way to do it with the native ESRI tooltips?
I have an example here:
http://jsfiddle.net/timw1984/5398h/
I know this is not an answer to your question but I hope it helps
Tim
TimWitt2
I just thought of another way that might work.
You could  change the tooltip depending on which button you press?
For example:
on(registry.byId("AreaButton"), "click", function () {
on(registry.byId("LineButton"), "click", function () {
     esri.bundle.toolbars.draw.start = "Click to start drawing a search line";
AkshayHarshe
Hi Olivia,
I was just trying to research this looks like you have following options:
To view all the customizable widget strings view any of the samples in a browser with debugging tools open and type console.dir(esri.bundle) in the console.
Tim Witt‌ is partly correct you can access the element and apply the tool tip.
Here is a hack that I did in the code it uses
on(document.getElementById("dijit_form_Button_2_label"), "click", function(){
  esri.bundle.toolbars.draw.freehand = "Click to start drawing a search line"
FOR THE FULL CODE USE FOLLOWING as SAMPLE:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="width=device-width,user-scalable=no">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Maps Toolbar</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/nihilo/nihilo.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
    <style>
      html, body, #mainWindow {
        font-family: sans-serif;
        height: 100%;
        width: 100%;
      html, body {
        margin: 0;
        padding: 0;
      #header {
        height: 80px;
        overflow: auto;
        padding: 0.5em;
    </style>
    <script src="http://js.arcgis.com/3.11/"></script>
    <script>
      var map, toolbar, symbol, geomTask;
      require([
        "esri/map",
        "esri/toolbars/draw",
        "esri/graphic",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "dojo/parser", "dijit/registry", "dojo/on",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
        "dijit/form/Button", "dijit/WidgetSet", "dojo/domReady!"
      ], function(
        Map, Draw, Graphic,
        SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,
        parser, registry, on
        parser.parse();
        map = new Map("map", {
          basemap: "streets",
          center: [-15.469, 36.428],
          zoom: 3
        map.on("load", createToolbar);
        // loop through all dijits, connect onClick event
        // listeners for buttons to activate drawing tools
        registry.forEach(function(d) {
          // d is a reference to a dijit
          // could be a layout container or a button
          if ( d.declaredClass === "dijit.form.Button" ) {
            d.on("click", activateTool);
        function activateTool() {
          var tool = this.label.toUpperCase().replace(/ /g, "_");
          toolbar.activate(Draw[tool]);
   map.hideZoomSlider();
        function createToolbar(themap) {
          toolbar = new Draw(map);
          toolbar.on("draw-end", addToMap);
        function addToMap(evt) {
          var symbol;
          toolbar.deactivate();
          map.showZoomSlider();
          switch (evt.geometry.type) {
            case "point":
            case "multipoint":
              symbol = new SimpleMarkerSymbol();
              break;
            case "polyline":
              symbol = new SimpleLineSymbol();
              break;
            default:
              symbol = new SimpleFillSymbol();
              break;
          var graphic = new Graphic(evt.geometry, symbol);
          map.graphics.add(graphic);
    </script>
  </head>
  <body class="nihilo">
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'">
    <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
      <span>Draw:<br /></span>
      <button data-dojo-type="dijit/form/Button">Point</button>
      <button data-dojo-type="dijit/form/Button">Multi Point</button>
      <button data-dojo-type="dijit/form/Button">Line</button>
      <button data-dojo-type="dijit/form/Button">Polyline</button>
      <button data-dojo-type="dijit/form/Button">Polygon</button>
      <button data-dojo-type="dijit/form/Button">Freehand Polyline</button>
      <button data-dojo-type="dijit/form/Button">Freehand Polygon</button>
      <!--The Arrow,Triangle,Circle and Ellipse types all draw with the polygon symbol-->
      <button data-dojo-type="dijit/form/Button">Arrow</button>
      <button data-dojo-type="dijit/form/Button">Triangle</button>
      <button data-dojo-type="dijit/form/Button">Circle</button>
      <button data-dojo-type="dijit/form/Button">Ellipse</button>
    </div>
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
  </div>
  </body>
</html>
Hope that helps
Akshay Harshe
Esri Technical Support
Akshay Harshe
