<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>
PointCloudLayer - change point size and density | Sample | ArcGIS API for
JavaScript 4.21
</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
#paneDiv {
width: 270px;
padding: 15px;
font-size: 14px;
.title {
margin-bottom: 10px;
font-size: 16px;
font-weight: bold;
.slider {
margin: 20px 0;
height: 40px;
width: 95%;
</style>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.21/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.21/"></script>
<script>
require([
"esri/Map",
"esri/views/SceneView",
"esri/layers/PointCloudLayer",
"esri/widgets/Slider"
], (Map, SceneView, PointCloudLayer, Slider) => {
// create slider for point size
const selectedPointsSize = 5;
const pointsizeSlider = new Slider({
container: "point-size-slider",
min: 1,
max: 15,
values: [selectedPointsSize],
steps: 0.5,
snapOnClickEnabled: false,
visibleElements: {
labels: true,
rangeLabels: true
// watch for changes on the sliders and update the renderer according to the new values
pointsizeSlider.on(
["thumb-change", "thumb-drag"],
pointsizeValueChanged
function pointsizeValueChanged(event) {
const newRenderer = pcLayer.renderer.clone();
newRenderer.pointSizeAlgorithm.size = event.value;
pcLayer.renderer = newRenderer;
const selectedPointsPerInch = 5;
const pointsperinchSlider = new Slider({
container: "points-per-inch-slider",
min: 1,
max: 40,
values: [selectedPointsPerInch],
steps: 1,
visibleElements: {
labels: true,
rangeLabels: true
pointsperinchSlider.on(
pointsperinchValueChanged
// create map and view
const map = new Map({
basemap: "gray-vector",
ground: "world-elevation"
const view = new SceneView({
container: "viewDiv",
map: map,
camera: {
heading: 210,
tilt: 78,
position: {
x: -8249335,
y: 4832005,
z: 50.7,
spatialReference: {
wkid: 3857
// create Point Cloud Layer with a renderer with set values for point size and point density
const pcLayer = new PointCloudLayer({
url: "https://tiles.arcgis.com/tiles/V6ZHFr6zdgNZuVG0/arcgis/rest/services/BARNEGAT_BAY_LiDAR_UTM/SceneServer",
renderer: {
type: "point-cloud-rgb", // autocasts as new pointCloudRGBRenderer()
field: "RGB",
pointSizeAlgorithm: {
type: "fixed-size",
useRealWorldSymbolSizes: false,
pointsPerInch: 5
// add layer to the map
map.add(pcLayer);
// add panel to the map
view.ui.add(document.getElementById("paneDiv"), "bottom-left");
</script>
</head>
<body>
<div id="viewDiv"></div>
<div id="paneDiv" class="esri-widget">
<div class="title">Customize point cloud layer:</div>
<div>Point size:</div>
<div id="point-size-slider" class="slider"></div>
<div>Points per inch:</div>
<div id="points-per-inch-slider" class="slider"></div>
</div>
</body>
</html>
