Is WKID only in ESRI products?
5292
04-03-2015 03:59 PM
LouieRowley
Is the WKID associated a spatial reference from a Standard or is that unique to ESRI products?
LouieRowley
DanPatterson_Retired
Pertinent and important reading...so that you are sure that everything is right
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
epsg > EPSG home
Home -- Spatial Reference
LouieRowley
Interesting stuff, European Petroleum Survey Group (EPSG) Background  .
Thank you for the links.
JeffJacobson
Generally, no.  There's a group called EPSG that standardizes these. (You can look them up on epsg.io.)
However, it is possible for Esri or others to define their own spatial reference systems and assign their own numbers, too.
For example, Google defined a coordinate system and gave it an ID of 600613. (The digits resemble the letters in the word "GOOGLE".) Later, this was adoped by Esri and they gave it the ID of 102100. It eventually became an EPSG standard with the ID of 3857. Older versions of ArcGIS Server would only recognize 102100, but once the EPSG assigned it an ID of their own, newer versions would recognize 3857 as well as the deprecated 102100.
