Is there a way to turn off the default Esri World Geocoder in the Search dijit and just use my local sources?
3762
07-23-2015 11:14 AM
DirkVandervoort
The attached picture shows the search option I want to remove so the search options are just my local sources (below the Esri World Geocoder).
TIA
JoshHevenor
geocoder = new Search({
    map: map,
    minCharacters: 3,
    activeSourceIndex: 'all'
}, "geocoder");
sources  = geocoder.get("sources");
// Change your sources
geocoder.set("sources", sources);
JoshHevenor
    map: map,
    minCharacters: 3,
}, "geocoder");
DirkVandervoort
Oops, a thousand pardons, I should have been more specific. The searched webmap is hosted at AGOL. The JSON data creating the searchable layers is show below. That being said, I can interrogate said JSON to build my search sources using the snippet you provided (which I think is also a JSAPI sample). Nonetheless, I didn't make the connection until your post. Thx
            "search": {
                "enabled": false,
                "disablePlaceFinder": true,
                "hintText": "Find Asset",
                "layers": [{
                    "id": "AnOutageStatus_9360",
                    "field": {
                        "name": "A_FIELD_NAME",
                        "exactMatch": false,
                        "type": "esriFieldTypeString"
                    "id": "AnOutageStatus_3600",
                    "field": {
                    "id": "AnOutageContext_2098",
                    "field": {
                    "subLayer": 1
                    "field": {
                    "subLayer": 0
