Is it possible to show a message on the map if the address is not within a certain distance of a FeatureLayer point?
1300
08-16-2021 12:23 PM
ericshark
I have a map that has layers added that works great, but is there something that lets me post a message if a layer marker is not found within a certain mile? Maybe within half a mile radius if no layer marker is found to post a message on the map that says "no marker found"?
UndralBatsukh
HI there,
You cannot directly use Map object to display messages. You can display messages on your map with the use of HTML element like div. For example, in this simple test app, you will see a message at the bottom left corner of the map whenever you click on the map.
Hop this helps,
-Undral
