Is it possible to get map extent values using ArcGIS JavaScript API 4x?
4201
6
09-23-2019 02:37 AM
rlttechcbe
I have been trying to start working on the javascript API.  I need to retrieve the feature layer name if any point features are there within the extent values. The extent values will differ, whenever we are performing zoom in or zoom out process. If not possible, how can we do this in some other way?
Thanks in Advance.
BenElan
The snippet below is from this sample
// Watch view's stationary property for becoming true.
watchUtils.whenTrue(view, "stationary", function() {
  // Get the new center of the view only when view is stationary.
  if (view.center) {
    var info =
      "<br> <span> the view center changed. </span> x: " +
      view.center.x.toFixed(2) +
      " y: " +
      view.center.y.toFixed(2);
    displayMessage(info);
  // Get the new extent of the view only when view is stationary.
  if (view.extent) {
    var info =
      "<br> <span> the view extent changed: </span>" +
      "<br> xmin:" +
      view.extent.xmin.toFixed(2) +
      " xmax: " +
      view.extent.xmax.toFixed(2) +
      "<br> ymin:" +
      view.extent.ymin.toFixed(2) +
      " ymax: " +
      view.extent.ymax.toFixed(2);
RobertScheitlin__GISP
In the 4.x api you just watch the views stationary property to be true then get the view.extent property.
BenElan
  if (view.center) {
    var info =
      " y: " +
  if (view.extent) {
    var info =
      "<br> xmin:" +
      " xmax: " +
      "<br> ymin:" +
      " ymax: " +
rlttechcbe
Ah! Thanks for the help! I'll check it out soon.
rlttechcbe
Thank you Mr.Ben Elan.. (view.extent) property is working now... Within this map extent can we able to retrieve the count of point features from the feature layer in the version of 4x series? This functionality is working in 3x series here.  But according to the 4x series still I am analyzing about it whether or not it is possible.
BenElan
The relevant code being
view.whenLayerView(featureLayer).then(function(layerView) {
          layerView.watch("updating", function(value) {
            if (!value) {
              // wait for the layer view to finish updating
              // query all the features available for drawing.
              layerView
                .queryFeatures({
                  geometry: view.extent,
                  returnGeometry: true
                .then(function(results) {
                    // Get count of features
                    console.log(results.features.length)
                .catch(function(error) {
                  console.error("query failed: ", error);
