INVALID CONTENT shows when I tried to use saveAs() of map
694
06-30-2021 01:15 AM
RandyLiu6410
Hi all,
I use react-arcgis to create WebScene and append FeatureLayer into the scene map. And then tried to use saveAs function to save map including layers. However, an error message shows "FAILED TO SAVE WEBSCENE DUE TO UNSUPPORTED OR INVALID CONTENT. SEE 'DETAILS.ERRORS' FOR MORE DETAILED INFORMATION". When I didn't add future to the map, the saveAs function works. Are the feature layers the problem that causes the issue?
ReneRubalcava
Honored Contributor
If you open the developer tools, can you see the detailed error? It will probably give you more info about what the problem is.
