InfoTemplate: embed an image?
3434
02-23-2011 11:56 AM
AlexanderStepanov
Hi All:
I was wondering if it is possible to embed/show an image in "infoTemplate", when clicking on a Graphic.
the second question is if it is possible to control size of 'infoTemplate' call-out, in such way that there will be no vertical scrolling.
Your advice is greatly appreciated,
Kind regards,
Alexander
DanielYim
What you can do to further customize the map's InfoWindow is to tie the content of the InfoWindow to a DOM object (such as a <div> in your page) instead of using the InfoTemplate.
So, for instance, you have this in your init():
        myMap.infoWindow.resize(300, 200);
        myMap.infoWindow.setContent(dijit.byId("infowinID").domNode);
        dojo.connect(myMap.infoWindow, "onShow", function() {
            dijit.byId("infowinID").resize();
And in your .html file, you have the following:
<div id="infowinID" dojoType="dijit.layout.ContentPane" title="Something">
    <img src="/your/path/toAnImage.png" alt="asdf" />
</div>
To stop scrollbars from appearing, maybe you'd have something like the following in your CSS:
#infowinID {
    overflow: hidden;
Personally, I find that the InfoTemplate is a quick and easy way to show content inside of an InfoWindow, but you lose a lot of customization as a tradeoff.
MelissaMathis
Hi All,
I am using the InfoWindow - DOM example code to embed an image(png) into an InfoWindow.
I can't seem to make it work correctly.  When I click in the map I see my image appear and it is embedded in the web page, rather than in an InfoWindow.  I am sure it is something easy but I can't figure it out.
Any help or examples on how to embed an image into an InfoWindow or Infotemplate would be great.   Thanks
var map;
      function init() {
         var initExtent = new esri.geometry.Extent({
          "xmin": 6333000,
   "ymin": 3246000,
          "xmax": 8860000,
          "ymax": 4900000,
          "spatialReference": {
            "wkid": 102100
        map = new esri.Map("map", {
          extent: initExtent
        dojo.connect(map,"onLoad", function(map) {map.infoWindow.resize(300, 200);} );
        map.addLayer(new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"));
        map.infoWindow.setContent(dijit.byId("infowinID").domNode);
        dojo.connect(map.infoWindow, "onShow", function() {
     dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    <div id="map" style="width:1024px; height:512px; border:1px solid #000;"></div>
    <<div id="infowinID" dojoType="dijit.layout.ContentPane" title="Something">
    <img src="1_341400071020000.xlsgraphics_files.png" />
</div>
  </body>
</html>
RobWaller
I didn't try running your code but just a quick look notice you have 2 start brackets on your infowinID DIV:
</div>
If that's how your tag actually is then that could cause a problem with the html structure. Not sure if that's your only issue but one thing to start with.
DanielYim
It's showing up down there because you haven't set it to show at the click's coordinates. I hope this helps.
dojo.connect(myMap, "onclick", function(evt) {
        myMap.infoWindow.setTitle("Some title");
        dijit.byId("infowinID").setContent("<img src='something.png' />');
        myMap.infoWindow.resize(355, 140);
        myMap.infoWindow.show(evt.screenPoint, myMap.getInfoWindowAnchor(evt.screenPoint));
MelissaMathis
Thank you Daniel for replying your code was helpful, I figured it was something simple.
I ended up using an InfoTemplate. I am posting my code to help others.
On the <img> tag, I didn't realize the <br> needed to be inside of the quotes.
var template = new esri.InfoTemplate();
template.setTitle("<b>Site Number</b>: ${site_no}");
template.setContent("<b>Name</b>: ${name}" + "<br><img src = thumbnail/chart.png>" +"<br> <a target='_blank' href = http://igs084/tables/${link} +>Excel Spreadsheet</a>");
