IdentityManager login does not appear
697
07-30-2021 09:27 AM
GeoSolver
This is the first time I've attempted to use IdentityManager.  I have a basic web app built from scratch with the ArcGIS JS API v4.18.  I need to display a feature layer that is hosted in ArcGIS Online and shared at the organization level.  Because the layer is secured I assumed I would be prompting the user to provide credentials and then get a token.  However, I came across this article about IdentityManager which states:
To use the IdentityManager simply include esri/identity/IdentityManager as part of your require statement. Once the application runs and requests a resource that is secure, the IdentityManager takes over and handles prompting the user for the appropriate credentials.
That sounds very convenient and simple so I added IdentityManager to the require statement, called the secured feature layer from ArcGIS Online, and added it to my map view's layers.
The view and basemap load in the app, but a login never appears and the API seems to be aware that I'm trying to display a secured feature layer because I get the following errors in the console.
The blurb I pasted above from ESRI's JS API documentation implies that calling the feature layer should have triggered IdentityManager to prompt the user for login, but it isn't doing that.  No login form appears.  What is the expected behavior here?
Is there a better way to prompt the user for login and enable the app to consume the secured feature layer hosted in ArcGIS Online?
Here's the full HTML and JS code for the app.  It's just a single page.
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="UTF-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <title>CAMS Viewer</title>
    <link rel="stylesheet" href="http://js.arcgis.com/4.18/esri/themes/light/main.css">
    <link rel="stylesheet" href="styles/style.css">
    <link rel="stylesheet" href="styles/spin.css">
    <link rel="shortcut icon" href="favicon.ico">
    <script src="http://js.arcgis.com/4.18/"></script>
    <script type="module">
        import {config} from './scripts/config.js';
        const legendDiv = document.getElementById("legend-panel-body");
        require([
            "esri/config",
            "esri/Map",
            "esri/identity/IdentityManager",
            "esri/views/MapView",
            "esri/widgets/BasemapGallery",
            "esri/layers/FeatureLayer",
            "esri/geometry/SpatialReference",
            "esri/tasks/support/Query",
            "esri/widgets/Search"
        ], function async(esriConfig, Map, esriId, MapView, BasemapGallery, FeatureLayer, SpatialReference, Query, Search) {
            esriConfig.apiKey = config.arcgisApiKey;
            const censusBlocksLayer = new FeatureLayer(config.censusBlocksUrl);
            const map = new Map({
                basemap: "arcgis-topographic", // Basemap layer service
                layers: [censusBlocksLayer]
            const view = new MapView({
                map: map,
                center: [-82.338, 27.927], // Longitude, latitude
                zoom: 11, // Zoom level
                container: "viewDiv", // Div element
            // basemap gallery widget
            const basemapGallery = new BasemapGallery({
                view: view
            view.ui.add(basemapGallery, {
                position: "top-right"
            // Search widget
            var searchWidget = new Search({
                view: view,
                container: document.querySelector('#search-widget-wrapper')
    </script>
</head>
<body>
    <div id="header">
        <div id="logo-container">
            <img src="img/hc_logo_graybg.png"/>
        </div>
        <div id="header-title">
            DEV
        </div>
        <div id="search-widget-wrapper"></div>
        <div id="header-widget-menu">
            <img src="img/basemap-24.png" class="widget-btn" data-toggle-selector=".esri-basemap-gallery"/>
        </div>
    </div>
    <div id="main-container">
        <div id="viewDiv"></div>
    </div>
</body>
</html>
