Situation:
I am writing an app that can load different sets of user-preferences, and that can programatically change the basemap.
I have a function who's job it is to detect the changes needed for the map, and this is called whenever a user changes their layers, basemap, or when user-preferences are loaded. (the point i'm making is that there's no 'user has changed the basemap' event from the basemap widget when my alternate user-preferences are loaded).
I'm trying to detect that the basemap is not the same as the one in the preferences, and only change the basemap attribute when a difference is detected.
I'm storing a basemap.toJSON() in my user-preferences.
What can I use in that, to correlate to a basemap (that was created from basemap.fromJSON() ) ??
I am not sure about the predictability of the order. I am not aware of any alternative,
Nathan,
Can you not just add a watch to the maps basemap property (assuming 4.x API since you did not specify)?
The watch will tell me when the actual map's Basemap is changed.
I'm trying to work out if what I store in my user-preferences data is the Basemap that's already in use on the map.
So you see, I'm trying to avoid changing the map's basemap. But I can't see what I can easily compare in my user-preferences to the on-screen Basemap.
Using the latest 4.10 api.
Nathan,
So the maps basemap property give you a string of the basemap name or a basemap object... Can you not use that to compare?
It appears the Basemap ID is generated uniquely each time I do a Basemap.fromJSON().
I wouldn't use the Title, that seems fragile.
The Basemap object itself cant be compared to what I store ... I store the Basemap.fromJSON().
I don't think I've tried comparing currentBasemap.toJSON() with my user-preferences storage...
The toJSON method returns a JSON-compatible object (good, it's not a string!), but that makes comparison tricky, because that's a 'deep attribute by attribute object comparison'. Is there no alternative? Would it be reliable - are the layer arrays stored in a predictable order?
Thanks so far Robert - I'll use the 'deep-equals' library and see if I get good results comparing the JSON-ready objects.
FYI, it's working.
I see now that, with 'well known names', portal-items, and direct URL sources, that the matter of 'basemap identity' is not a trivial one.
Given that, this method of checking identity seems reasonable enough - I guess it would be nice to make it an official feature of the toJSON() methods, to help avoid running into regression issues.
Many thanks.
