I cannot get my legend to load, any help is appreciated.
565
05-03-2020 03:40 PM
CodyHilton
New Contributor II
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no" />
<title>Proximity of Fastfood to Schools</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.15/esri/themes/light/main.css" />
<script src="https://js.arcgis.com/4.15/"></script>
<script>
require(["esri/Map",
"esri/views/MapView",
"esri/layers/FeatureLayer",
"esri/widgets/Legend"
], function(Map, MapView, FeatureLayer, Legend){
var map = new Map({
basemap: "streets"
var view = new MapView({
container: "viewDiv",
map: map,
zoom: 8,
center: [282.5, 39]
var publicschoolsLayer = new FeatureLayer({
url: "https://gis.mdfoodsystemmap.org/server/rest/services/FoodMapMD/Ret_MD_Food_Map_Services/MapServer/135"
map.add(publicschoolsLayer);
var fastfoodLayer = new FeatureLayer({
url: "https://gis.mdfoodsystemmap.org/server/rest/services/FoodMapMD/Ret_MD_Food_Map_Services/MapServer/123"
map.add(fastfoodLayer);
var legend = new Legend({
view: view,
layerInfos: [{
layer: featureLayer,
title: "Locations of FastFood and Schools"}
view.ui.add(legend, "bottom-right");
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
RobertScheitlin__GISP
Cody,
   This works. Your issue was that you were setting the layerInfos manually to a var called featureLayer which did not exist in your code.
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    ], function (Map, MapView, FeatureLayer, Legend) {
      var map = new Map({
        basemap: "streets"
        map: map,
        zoom: 8,
        center: [282.5, 39]
        view: view
  </script>
</head>
<body>
</body>
</html>
Cody,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
      var map = new Map({
        basemap: "streets"
        map: map,
        zoom: 8,
        center: [282.5, 39]
        view: view
  </script>
</head>
<body>
</body>
</html>
CodyHilton
New Contributor II
Aw okay, I see now. Thank you so much!
