Hi Robert, yep, I agree, this should be simple...Anyway, This is the code to dynamically load the map layers by looping through the map service:
<script src="https://js.arcgis.com/3.27/"></script>
<script>
//Dynamic layer script. Loops through a map service for all layers and automatically lists them in a map.
var layer, map, mapLegend, visible = [];
require([
"esri/map",
"esri/layers/ArcGISDynamicMapServiceLayer",
"dojo/dom",
"dojo/on",
"dojo/query",
"dojo/_base/array",
"dojo/domReady!"
], function(
Map, ArcGISDynamicMapServiceLayer,
dom, on, query, arrayUtils
map = new Map(
"map",
{basemap: "satellite",
center: [-102, 54.75],
slider: true,
nav: false,
zoom: 6});
//Point the url below to the published mapservice you want to use
layer = new ArcGISDynamicMapServiceLayer("https://xxxxxxx/arcgis/rest/services/Test/DMAF_Application_V3/MapServer",{
"showAttribution": true, "opacity": 0.7, mode: ArcGISDynamicMapServiceLayer.MODE_ONDEMAND,
outFields: ["*"],
layer.on("load", buildLayerList);
map.addLayer(layer);
function buildLayerList() {
var items = arrayUtils.map(layer.layerInfos, function(info, index) {
if (info.defaultVisibility) {
visible.push(info.id);
return "<input type='checkbox' class='list_item'" + (info.defaultVisibility ? "checked=checked" : "") + "' id='" + info.id + "'' /><label for='" + info.id + "'>" + info.name + "</label>";
var ll = dom.byId("layer_list");
ll.innerHTML = items.join(' ');
layer.setVisibleLayers(visible);
on(ll, "click", updateLayerVisibility);
function updateLayerVisibility() {
var inputs = query(".list_item");
var input;
visible = [];
arrayUtils.forEach(inputs, function(input) {
if (input.checked) {
visible.push(input.id);
//if there aren't any layers visible set the array to be -1
if (visible.length === 0) {
visible.push(-1);
</script>
And this is the print code:
<script>
//Print a map script
var Printapp = {};
require([
"esri/map",
"esri/layers/FeatureLayer",
"esri/dijit/Print",
"esri/tasks/PrintTemplate",
"esri/request",
"esri/config",
"dojo/_base/array",
"dojo/dom",
"dojo/parser",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dojo/domReady!"
], function(
Map, FeatureLayer,
Print, PrintTemplate,
esriRequest, esriConfig,
arrayUtils, dom, parser
parser.parse();
Printapp.printUrl = "https://xxxxxxxxxxxx/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task";
esriConfig.defaults.io.proxyUrl = "/proxy/";
Printapp.map = new Map("map",
basemap: "topo",
slider: true,
nav: false,
zoom: 6});
// add graphics for layers
var layerUrl = "https://xxxxxxxxxxx/arcgis/rest/services/Test/DMAF_Application_V3/MapServer";
var printFeatureLayer = new FeatureLayer(layerUrl, {
"mode": FeatureLayer.MODE_SNAPSHOT
Printapp.map.addLayer(printFeatureLayer);
// get print templates from the export web map task
var printInfo = esriRequest({
"url": Printapp.printUrl,
"content": { "f": "json" }
printInfo.then(handlePrintInfo, handleError);
function handlePrintInfo(resp) {
var layoutTemplate, templateNames, mapOnlyIndex, templates;
layoutTemplate = arrayUtils.filter(resp.parameters, function(param, idx) {
return param.name === "Layout_Template";
if ( layoutTemplate.length === 0 ) {
console.log("print service parameters name for templates must be \"Layout_Template\"");
return;
templateNames = layoutTemplate[0].choiceList;
// remove the MAP_ONLY template then add it to the end of the list of templates
mapOnlyIndex = arrayUtils.indexOf(templateNames, "MAP_ONLY");
if ( mapOnlyIndex > -1 ) {
var mapOnly = templateNames.splice(mapOnlyIndex, mapOnlyIndex + 1)[0];
templateNames.push(mapOnly);
// create a print template for each choice
templates = arrayUtils.map(templateNames, function(ch) {
var plate = new PrintTemplate();
plate.layout = plate.label = ch;
plate.format = "PDF";
plate.layoutOptions = {
"authorText": "Made by: xxxxxxxxx",
"copyrightText": "<copyright info here>",
"legendLayers": [],
"titleText": "Title",
"scalebarUnit": "Miles"
return plate;
// create the print dijit
Printapp.printer = new Print({
"map": Printapp.map,
"templates": templates,
url: Printapp.printUrl
}, dom.byId("print_button"));
Printapp.printer.startup();
function handleError(err) {
console.log("Something broke: ", err);
</script>
In the page, the print script is directly under the dynamic map script code, which runs first. The trouble is, in this section in the print script:
basemap: "topo",
slider: false,
nav: false,
zoom: 6});
it is insisting I have a new map. If I change it or do anything to this the code doesn't work. I have been trying many things, too many to go into details here, but usually the print button disappears or when I click it, nothing happens. Sometimes the generate legend script stops working too. I just want this print code to printout what is showing in the current map view. I have a resizable div section at the bottom of the mapping screen which I'm going to use in future for attribute tables, and when I drag resize it up and down, I can see the topo basemap drawing underneath, which I don't want.
Thanks!
