How to get the coordinate searched from callback function of QueryTask execute
643
06-15-2020 01:42 PM
AdeebFarhan
I have a function checkCoverage for a particular x,y coordinate. Which executes a QueryTask. And get the result in a call back function.  A Query Object is passed to QueryTask.execute(). The coordinate to search is set in Query as below.
Is there any way to find the coordinate (Point x and y) which was set in Query object from the callback function (reportMyCoverage)  result object?
This is required because I trying to run this Check Coverage Function for multiple coordinates.
           checkCoverage: function (x, y ) {
                var map = mySelfSearch.map;
                var geographicPoint = new Point(x, y);
                var projectedPoint=webMercatorUtils.geographicToWebMercator(geographicPoint);
                var graphic = new Graphic(projectedPoint);
                if (mySelfSearch.map.getLayer('coverageCheckGraphics_point') != undefined) { mySelfSearch.map.getLayer('coverageCheckGraphics_point').clear(); }
                mySelfSearch.map.getLayer('coverageCheckGraphics_point').add(graphic);
                try{
                     mySelfSearch.map.getLayer('coverageCheckGraphics_point').graphics[0]);
                    var chkpnt = map.getLayer('coverageCheckGraphics_point').graphics[0].geometry;
                    var query = new Query();
                    var fiberCovCompletionFlagCheck = mySelfSearch.fiberCoverageCompletion;
                    query.geometry = chkpnt;
                    query.where = " 1=1 ";
                    query.returnGeometry = true;
                    query.spatialRelationship = "esriSpatialRelIntersects";
                    var queryTaskFiber = new QueryTask(mySelfSearch.queryURLFiber);
                    query.outFields = ['*'];
                    queryTaskFiber.execute(query, mySelfSearch.reportMyCoverage, function (error) { console.log(getADBDate() + "Error occured in queryTaskFiber.execute  " + error.message); });
                    mySelfSearch.fiberCoverageCompletion=false;
                } catch (e) {
                    console.log("Error occured in check coverage  " + e.message);
reportMyCoverage: function (result)
             reportMyCoverage: function (result) {
               var isCovered = result.features.length > 0;
                if (isCovered) {
                    mySelfSearch.fiberCoverage = 'TRUE';
                } else {
                    mySelfSearch.fiberCoverage = 'FALSE';
RobertScheitlin__GISP
Adeeb,
  Sure here is how. This is call JS Closure. You pass the point object to the result function.
  function(result){
    mySelfSearch.reportMyCoverage(result, chkpnt);
  function (error) {
reportMyCoverage: function (pntGeom, result) {
  if (isCovered) {
    console.log(pntGeom);
  } else {
