How to get a layer in the map using layer name?
8197
11
06-17-2019 12:30 PM
GarryStewart
Hi, I'm working with the javascript 3.2 api, and have a map that loads from a pre-defined web map.   I'm now wanting to get a handle to a layer in the map using the layer name.
I've managed to write some javacript code that locates the layerInfo for the said layer, but I have no idea how to get the actual layer from the map.
_getFeatureLayer: function(layerName) {
var layer;
for (var j = 0, jl = this.map.layerIds.length; j < jl; j++)
   var currentLayerName = this.map.layerIds;
   var currentLayer = this.map.getLayer(currentLayerName);
   if (currentLayer.layerInfos.length > 0)
      layer = this._findSubLayerByName(currentLayer, layerName);
      if (layer != null)
         break;
return layer;
_findSubLayerByName: function (parentLayer, subLayerName)
   var layer;
   for (var j = 0, jl = parentLayer.layerInfos.length; j < jl; j++)
      var layerInfo = parentLayer.layerInfos;
      if (layerInfo.name == subLayerName)
         /* The correct layer is located, but how do I actually get the layer, this does not work. */
         var subLayerUrl = parentLayer.url + "/" + j;
         layer = new FeatureLayer(subLayerUrl); /* This doesn't give me the layer that is already added to the map */
         break;
   return layer;
GarryStewart
Hi Robert, can you use a selection geometry with a QueryTask?  Thanks,
GarryStewart
Nevermind, that was a dumb question … of course you can that's what a GIS is all about.
