How to draw multiple polygons on an Esri map and get the coordinates of each vertex?
1598
05-20-2021 05:44 AM
SiyabongaKubeka
Hi All
I am currently using the code below to display the esri map, draw a polygon and extract data from the map, i.e the coordinates of each vertex of the polygon. I am using JavaScript. Now I want to be able to draw multiple polygons. I have added the "continuous" on creationMode, but I can not add multiple polygons, please assist.
<html><head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>GIS Map for CRM</title>
<link href="https://js.arcgis.com/4.14/esri/themes/light/main.css" rel="stylesheet">
<script src="https://js.arcgis.com/4.14/"></script>
<style>
html,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
.esri-sketch__section.esri-sketch__tool-section:last-of-type {
display: none;
.esri-sketch__section.esri-sketch__tool-section:nth-child(2) {
border-right: none;
button[title="Reshape"]{
display: none;
button[title="Transform"]{
display: none;
</style>
<script>
var lon;
var lat;
var crmLatitude;
var crmLongitude;
var latlon;
var provinces;
var municipalities;
var districts;
var wards;
var showWards = [];
var testVariable;
require([
"esri/Map",
"esri/views/MapView",
"esri/WebMap",
"esri/layers/FeatureLayer",
"esri/tasks/QueryTask",
"esri/tasks/support/Query",
"esri/config",
"esri/widgets/Sketch",
"esri/layers/GraphicsLayer",
"esri/widgets/ScaleBar"],
function(Map, MapView, WebMap, FeatureLayer, QueryTask, Query,
esriConfig, Sketch, GraphicsLayer, ScaleBar) {
esriConfig.portalUrl = "https://portal.environment.gov.za/portal";
const featureLayerUrl = 'https://portal.environment.gov.za/server/rest/services/Boundary/Wards/MapServer/0';
var webmap = new WebMap({
portalItem: {
var graphicsLayer = new GraphicsLayer();
var view = new MapView({
map: webmap,
container: "viewDiv",
popup: null
var featureLayer = new FeatureLayer({
url: featureLayerUrl
webmap.add(featureLayer);
webmap.layers.add(graphicsLayer);
var sketch = new Sketch({
layer: graphicsLayer,
view: view,
availableCreateTools: ["polygon"],
creationMode: "continuous",
view.ui.add(sketch, {
position: "top-right"
var scaleBar = new ScaleBar({
view: view
// Add widget to the bottom left corner of the view
view.ui.add(scaleBar, {
position: "bottom-left"
sketch.on('create', function (event) {
// check if the create event's state has changed to complete indicating
// the graphic create operation is completed.
if (event.state === "complete") {
if (view.zoom >= 11) {
let gra = event.graphic.clone();
event.graphic.layer.removeAll();
gra.symbol.color = "red";
gra.layer.add(gra);
console.log(view.zoom);
console.log("X = ", gra.geometry.x);
console.log("Y = ", gra.geometry.y);
console.log("Lat = ", event.graphic.geometry.latitude);
console.log("Long = ", event.graphic.geometry.longitude);
lat = event.graphic.geometry.latitude;
lon = event.graphic.geometry.longitude;
zoomLevel = view.zoom;
for (var i = 0; i < gra.geometry.rings.length; i++){
for (var p = 0; p < gra.geometry.rings[i].length; p++){
crmLatitude = String(gra.geometry.getPoint(i, p));
crmLongitude = String(gra.geometry.getPoint(i, p));
var LatLon = String(gra.geometry.rings[i][p]);
console.log(LatLon);
latlon = LatLon;
debugger;
else{
alert("please zoom in");
event.graphic.layer.remove(event.graphic);
view.on('click', function(event){
var queryTask = new QueryTask({
var query = new Query();
query.geometry = view.toMap(event);
query.distance = 0;
query.units = "meters";
query.spatialRelationship = "intersects";
query.returnGeometry = true;
query.outFields = [ "PROVINCE", "DCS12_NAME", "S12_NAME", "WARD_NO" ];
queryTask.execute(query).then(function(results){
var feat = results.features[0];
provinces = feat.attributes.PROVINCE;
wards = feat.attributes.WARD_NO;
districts = feat.attributes.DCS12_NAME;
municipalities = feat.attributes.S12_NAME
showWards.push(wards);
var xwards = showWards.toString();
console.log(provinces);
console.log(wards);
console.log(districts);
console.log(municipalities);
console.log(xwards);
//Call to CRM to populate the lookup field for Province
debugger;
window.parent.Xrm.WebApi.online.retrieveMultipleRecords("dea_province", "?$select=dea_name,dea_provinceid&$filter=dea_name eq '" + provinces + "'").then(
function success(results) {
debugger;
for (var i = 0; i < results.entities.length; i++) {
var dea_name = results.entities[i]["dea_name"];
var dea_provinceid = results.entities[i]["dea_provinceid"];
//Populate lookup
var lookupValue = new Array();
lookupValue[0] = new Object();
lookupValue[0].id = dea_provinceid; // GUID of the lookup id
lookupValue[0].name = dea_name; // Name of the lookup
lookupValue[0].entityType = "dea_province"; //Entity Type of the lookup entity
window.parent.Xrm.Page.getAttribute("dea_province").setValue(lookupValue);
function(error) {
Xrm.Utility.alertDialog(error.message);
//Call to CRM to populate the lookup field for the Local Municipality
window.parent.Xrm.WebApi.online.retrieveMultipleRecords("dea_localmunicipality", "?$select=dea_localmunicipalityid,dea_name&$filter=dea_name eq '" + municipalities + "'").then(
var dea_localmunicipalityid = results.entities[i]["dea_localmunicipalityid"];
//Populate lookup
lookupValue[0].id = dea_localmunicipalityid; // GUID of the lookup id
lookupValue[0].entityType = "dea_localmunicipality"; //Entity Type of the lookup entity
window.parent.Xrm.Page.getAttribute("dea_localmunicipality").setValue(lookupValue);
function(error) {
//Call to CRM to populate the lookup field for District Municipality
window.parent.Xrm.WebApi.online.retrieveMultipleRecords("dea_districtmunicipality", "?$select=dea_districtmunicipalityid,dea_name&$filter=dea_name eq '" + districts + "'").then(
var dea_districtmunicipalityid = results.entities[i]["dea_districtmunicipalityid"];
//Populate lookup
lookupValue[0].id = dea_districtmunicipalityid; // GUID of the lookup id
lookupValue[0].entityType = "dea_districtmunicipality"; //Entity Type of the lookup entity
window.parent.Xrm.Page.getAttribute("dea_districtmunicipality").setValue(lookupValue);
function(error) {
//Populate the coordinates field
debugger;
window.parent.Xrm.Page.getAttribute("dea_latitude").setValue(latlon);
window.parent.Xrm.Page.getAttribute("dea_longitude").setValue(latlon);
window.parent.Xrm.Page.getAttribute("dea_ward").setValue(xwards);
//THE END OF CALLS TO CRM
.catch(function (error) {
console.error("Query Error: " + error);
alert("The polygon has been drawn outside the South African borders, please refresh and re-draw inside the South African borders");
</script>
<meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta></head>
</head>
<body style="overflow-wrap: break-word;">
<div id="viewDiv"></div>
</body></html>
@ RobertScheitlin__GISP
