How to check-on/off All of FeatureTable's rows
1347
04-02-2021 12:16 PM
ShaningYu
Honored Contributor
Refer to https://developers.arcgis.com/javascript/latest/sample-code/widgets-featuretable-map/, I loaded ESRI's FeatureTable widge into my App.  What is the way to check on/off all of the rows dynamically thruough JavaScript code?  Thanks if you can provide your hint.
ReneRubalcava
Honored Contributor
You can select the rows using the object ids of the source layer.
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-FeatureTable.html#selectR...
// select all rows
const oids = await featureTable.layer.queryObjectIds();
featureTable.selectRows(oids);
ShaningYu
Honored Contributor
Rene: Thanks for your response.  What's the code to add/remove All of the row?  Could you help?
