How to change the Route Direction when click on button Car/Truck/Walking
3227
03-26-2015 07:10 AM
AshishNagrale
<!DOCTYPE html>
<html>
<head>
  <title>Driving Directions</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.13/dgrid/css/dgrid.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
  <style>
    html,body {
      font-family: Arial,Helvetica,sans-serif;
      height:100%;
      margin:0;
    #map {
      height:100%;
      overflow:hidden;
    #dialog {
      top: 15px;
      right: 15px;
      position: absolute;
      padding: 5px;
      width: 380px;
      background-color: #ffffff;
      border-radius: 5px;
      margin: 8px;
      box-shadow: 0px 1px 3px #888;
    #dialog input{
      margin: 0.5em;
      width: 20em;
    #grid{
      overflow-x:hidden;
      overflow-y:auto;
    input#directions {
      margin: 0.5em auto;
      width:  8em;
      display: block;
    .dgrid-row{
      padding:5px;
      margin-bottom:5px;
      min-height:50px;
      border-bottom: solid 1px #C0C0C0;
    .dgrid-row .detail div {
      cursor: pointer;
    .dgrid-row .detail div:hover{
      text-decoration:underline;
    .distance{
      float:right;
      color:#C0C0C0;
      font-style:italic;
  </style>
  <script src="http://js.arcgis.com/3.13/"></script>
  <script>
    var map;
    require([
      "esri/map", "esri/tasks/locator", "esri/SpatialReference",
      "esri/tasks/RouteTask", "esri/tasks/RouteParameters",
      "esri/tasks/FeatureSet", "esri/units", "esri/config", "esri/lang",
      "esri/symbols/PictureMarkerSymbol", "esri/graphic",
      "esri/symbols/SimpleLineSymbol",
      "esri/urlUtils",
      "dojo/promise/all", "dojo/_base/array", "esri/Color",
      "dojo/dom", "dojo/dom-construct", "dojo/on", "dojo/number",
      "dgrid/Grid", "dojo/domReady!"
    ], function(
      Map, Locator, SpatialReference,
      RouteTask, RouteParameters,
      FeatureSet, esriUnits, esriConfig, esriLang,
      PictureMarkerSymbol, Graphic,
      SimpleLineSymbol,
      urlUtils,
      all, arrayUtils, Color,
      dom, domConstruct, on, number,
      Grid
      var locator, routeTask, routeParams = [], segmentGraphic, directionFeatures, grid;
      on(dom.byId("directions"), "click", getDirections);
      on(dom.byId("Car"), "click", getCarDirections);
      on(dom.byId("Truck"), "click", getTruckDirections);
      on(dom.byId("Walking"), "click", getWalkingDirections);
      // Use a proxy to access the routing service, which requires credits
      urlUtils.addProxyRule({
        urlPrefix : "route.arcgis.com",
        //proxyUrl : "/sproxy/"
        proxyUrl: "http://WebServer/proxy/proxy.ashx
      //Create a map with an initial extent. Change the extent to match the area you would like to show.
      map = new Map("map", {
        basemap: "streets",
        center: [-117.185, 34.065],
        zoom: 13
      //Add a geocoding server as the locator. This locator will be used to find the origin and destination coordinates by input addresses.
      locator = new Locator("http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer");
      locator.outSpatialReference = map.spatialReference;
      //Fire errorHandler if the locator return en error.
      locator.on("error", errorHandler);
      //Add a network analyst server with related parameters to execute the routing task.
      routeTask = new RouteTask("http://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World");
      routeParams = new RouteParameters();
      routeParams.stops = new FeatureSet();
      routeParams.returnRoutes = false;
      routeParams.returnDirections = true;
      routeParams.directionsLengthUnits = esriUnits.MILES;
      routeParams.outSpatialReference = new SpatialReference({ wkid:102100 });
      //Show the route when the routing task is solved successfully, otherwise fire errorHandler.
      routeTask.on("solve-complete", showRoute);
      routeTask.on("error", errorHandler);
      //Execute a routing task when clicking "get direction".
      function getDirections() {
        routeParams.stops.features = [];
        map.graphics.clear();
        //Get origin address.
        var optionsFrom = {
          address: { "SingleLine": dom.byId("fromTxf").value },
          outFields: ["Loc_name"]
        var fromAddress = locator.addressToLocations(optionsFrom);
        //Get destination address.
        var optionsTo = {
          address: { "SingleLine": dom.byId("toTxf").value },
        var toAddress = locator.addressToLocations(optionsTo);
        //Use dojo/promises/all to manage multiple asynchronous tasks. Once both geocodes finish, a route is calculated.
        //http://livedocs.dojotoolkit.org/dojo/promise/all
        all({
          to: toAddress
        }).then(configureRoute);
      function getCarDirections(){
            alert('Car button click');
            function getTruckDirections(){
            alert('Truck button click');
            function getWalkingDirections(){
            alert('Walking button click');
      //Check if the origin and destination addresses are executed successfully
      //and solve the routing task.
      function configureRoute(results) {
        //Configure symbols to be used for destinations and route segments.
        var fromSymbol = new PictureMarkerSymbol({
          "angle":0,
          "xoffset":0,
          "yoffset":10,
          "type":"esriPMS",
          "url":"http://static.arcgis.com/images/Symbols/Shapes/GreenPin1LargeB.png",
          "contentType":"image/png",
          "width":24,
          "height":24
        var toSymbol = new PictureMarkerSymbol({
          "angle":0,
          "xoffset":0,
          "yoffset":12,
          "type":"esriPMS",
          "url":"http://static.arcgis.com/images/Symbols/Shapes/RedPin1LargeB.png",
          "width":24,
          "height":24
        var fromStop = getCandidate(results.from);
        if ( fromStop === null ) {
          errorHandler("The origin address is invalid");
        } else {
          var fromGraphic = new Graphic(fromStop.location, fromSymbol, { address:fromStop.address });
          routeParams.stops.features[0] = map.graphics.add(fromGraphic);
        var toStop = getCandidate(results.to);
        if ( toStop === null ) {
          errorHandler("The destination address is invalid");
        } else {
          var toGraphic = new Graphic(toStop.location, toSymbol, { address:toStop.address });
          routeParams.stops.features[1] = map.graphics.add(toGraphic);
        if ( fromStop !== null && toStop !== null ) {
          routeTask.solve(routeParams);
      //Handle all the coordinate candidates of the origin and destination addresses and
      //return the candidate with the highest score.
      function getCandidate(candidates){
        var stop = null, score = 0;
        arrayUtils.forEach(candidates, function(candidate){
          if( candidate.score > score ) {
           stop = candidate;
           score = candidate.score;
        return stop;
      //Show the result of the routing task.
      function showRoute(e) {
      debugger;
        var data = [];
        if ( grid ) {
          grid.refresh();
        var directions = e.result.routeResults[0].directions;
        directionFeatures = directions.features;
        var routeSymbol = new SimpleLineSymbol().setColor(new Color([0,0,255,0.5])).setWidth(4);
        // Zoom to results.
        map.setExtent(directions.mergedGeometry.getExtent(), true);
        // Add route to the map.
        var routeGraphic = new Graphic(directions.mergedGeometry, routeSymbol);
        map.graphics.add(routeGraphic);
        routeGraphic.getShape().moveToBack();
        map.setExtent(directions.extent, true);
        //Display the directions.
        var directionsInfo = e.result.routeResults[0].directions.features;
        var totalDistance = number.format(directions.totalLength);
        var totalLength = number.format(directions.totalTime);
        data = arrayUtils.map(directionsInfo,function(feature,index){
          return {
            "detail": feature.attributes.text,
            "distance": number.format(feature.attributes.length,{places:2}),
            "index": index
        grid = new Grid({
          renderRow: renderList,
          showHeader:false
        }, "grid");
        grid.renderArray(data);
        grid.on(".dgrid-row:click", zoomToSegment);
      function renderList(obj,options){
        var template = "<div class='detail'><div style='max-width:70%;float:left;'>${detail}</div><span style='float:right;' class='distance'>${distance} mi</span></div>";
        return domConstruct.create("div", { innerHTML: esriLang.substitute(obj, template) });
      //Display any errors that were caught when attempting to solve the route.
      function errorHandler(err) {
        alert("An error occured\n" + err);
      function zoomToSegment(e) {
        //Grid row id corresponds to the segment to highlight
        var index = grid.row(e).id;
        var segment = directionFeatures[index];
        var segmentSymbol = new SimpleLineSymbol().setColor(new Color([255,0,0,0.5])).setWidth(8);
        map.setExtent(segment.geometry.getExtent(), true);
        if ( !segmentGraphic ) {
          segmentGraphic = map.graphics.add(new Graphic(segment.geometry, segmentSymbol));
        } else {
          segmentGraphic.setGeometry(segment.geometry);
  </script>
</head>
<body class="claro">
  <div id="map"></div>
  <div id="dialog">
    <div>
      <label for="fromTxf"><img src="http://static.arcgis.com/images/Symbols/Shapes/GreenPin1LargeB.png" width=24 height=24></label>
      <input type="text" id="fromTxf" value="380 New York St, Redlands, CA 92373">
    </div>
    <div >
      <label for="toTxf"><img src="http://static.arcgis.com/images/Symbols/Shapes/RedPin1LargeB.png" width=24 height=24></label>
      <input type="text" id="toTxf" value="1320 Mona Ave, Redlands, CA 92374">
    </div>
    <input id="directions" type="button" value="Get Directions">
    <div>
    <input id="Car" type="button" value="Get Car Route">
    <input id="Truck" type="button" value="Get Truck Route">
    <input id="Walking" type="button" value="Get Walking Route">
    </div>
    <div id="directionsDetail" style="clear:both;">
      <div id="grid"></div>
    </div>
  </div>
</body>
</html>
Message was edited by: Ashish Nagrale
