Here is a bit of a sledgehammer way to force the issue (in typescript, but it should be even simpler in plain javascript):
// set the mapview surface cursor to default
const mapContainer = document.getElementById("map-container");
if (mapContainer) {
for (let i = 0; i < mapContainer.childNodes.length; i++) {
const rootElement = mapContainer.childNodes[i] as Element;
if ((mapContainer.childNodes[i] as Element).classList.contains("esri-view-root")) {
for (let j = 0; j < rootElement.childNodes.length; j++) {
const viewSurface = rootElement.childNodes[j] as Element;
if (viewSurface.classList.contains("esri-view-surface")) {
(viewSurface as HTMLElement).style.cursor = "auto";
and to restore your crosshair sketch cursor:
// set the mapview surface cursor to crosshair
if (mapContainer) {
(viewSurface as HTMLElement).style.cursor = "crosshair";
