How make custom basemaps toogle
1846
13
10-05-2018 05:47 AM
TokarAndrii
Hi, I have such code. Need to show only custom basemaps (that published as services)  at 2 different frames with sync effect. Why It doesn't work, how fix it?
<script>
    var map, map2;
    require(["esri/map", "dojo/on", "esri/dijit/Basemap",
            "esri/dijit/BasemapGallery", "esri/dijit/BasemapLayer", "esri/arcgis/utils", "dojo/parser",
            "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane", "dojo/domReady!"],
        function (Map, on, Basemap, BasemapGallery, BasemapLayer, arcgisUtils, parser) {
            parser.parse();
            var basemaps = [];
            var customBasemapLayer1 = new BasemapLayer({
                url: "http://ags-pro.ecomm.pp.ua/portal/apps/webappviewer/index.html?id=6e5ced0707fd44219eb95209680784d9"
            var customBasemapLayer2 = new BasemapLayer({
            var customBasemap1 = new Basemap({
                layers: [customBasemapLayer1],
                title: "custom Basemap1",
                thumbnailUrl: "custom.png"
            var customBasemap2 = new Basemap({
                layers: [customBasemapLayer2],
                title: "custom Basemap2",
            basemaps.push(customBasemap1);
            basemaps.push(customBasemap2);
            map = new Map("map", {
                basemap: "customBasemap1", //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
                center: [37.15, 48.18,], // longitude, latitude
                zoom: 12
            map2 = new Map("map2", {
                basemap: "customBasemap2", //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
                zoom: 12
            //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
            var basemapGallery = new BasemapGallery({
                showArcGISBasemaps: false,
                map: map,
                basemaps: basemaps,
            }, "basemapGallery");
            basemapGallery.startup();
            basemapGallery.on("error", function (msg) {
                console.log("basemap gallery error:  ", msg);
            var basemapGallery2 = new BasemapGallery({
                map: map2,
                basemaps: basemaps,
            }, "basemapGallery2");
            basemapGallery2.startup();
            basemapGallery2.on("error", function (msg) {
            //Fires when the zoom is complete.
            map.on("zoom-end", function (evt) {
                map2.setZoom(evt.target.__LOD.level);
            map2.on("zoom-end", function (evt) {
                map.setZoom(evt.target.__LOD.level);
            // Fires when a mouse button is pressed down and the user starts to drag the mouse.
            map.on("mouse-drag-start", function (evt) {
                //The resume() method will cause the listener to be called again.
                handler1.resume();
            map2.on("mouse-drag-start", function (evt) {
                handler2.resume();
            //https://developers.arcgis.com/javascript/3/jsapi/map-amd.html - see docs
            /*The pausable() method provides a means for pausing an event listener, while still preserving the listeners order and state.
             The pausable() method can be called just like on(). The only difference is the returned signal handler will include pause() and resume() methods.*/
            //Fires when the pan is complete.
            var handler1 = on.pausable(map, "pan-end", function (evt) {
                //The pause() method will cause the listener to not be called when the specified event takes place
                handler2.pause();
                map2.centerAt(evt.extent.getCenter());
            var handler2 = on.pausable(map2, "pan-end", function (evt) {
                handler1.pause();
                map.centerAt(evt.extent.getCenter());
</script>
<body class="claro">
<header>
    <div class="toogle" style="position:absolute; left:100px; top:20px; z-Index:999;">
        <div data-dojo-type="dijit/TitlePane"
             data-dojo-props="title:'Switch Basemap1', open:false">
            <div data-dojo-type="dijit/layout/ContentPane"
                 style="width:380px; height:280px; overflow:auto;">
                <div id="basemapGallery"></div>
            </div>
        </div>
    </div>
    <div class="toogle" style="position:absolute; right:100px; top:20px; z-Index:999;">
             data-dojo-props="title:'Switch Basemap2', open:false">
                <div id="basemapGallery2"></div>
            </div>
        </div>
    </div>
</header>
<div class="mapContainer">
    <div id="map" class="claro"></div>
    <div id="map2" class="claro"></div>
</div>
RobertScheitlin__GISP
Tokar,
   The url that you are attempting to use for a basemap is actually a Web App url not a map service so that is your issue:
is a WAB application url.
You need a map service url (normally a cached/tiled map service).
TokarAndrii
Tokar,
   That is still a url to a WAB app NOT a map service.
Notice mirnograd.ecomm-services.net/portal/apps/webappviewer/index.html is is a clue that you are trying to use an app.
The url should have MapServer in the url.
TokarAndrii
http://ags-pro.ecomm.pp.ua/portal/home/webmap/viewer.html?webmap=97459e60f61d4f3eb9c27127f42fd67d  is it right link? sorry i am not good yet at differences between them (my gis colleags says it is right link but it not work and cant understand where problem at code or at link)..
Tokar,
  No it is NOT the right link. As I said already the fact that the url has apps/webappviewer/index.html
is is a clue that you are trying to use an app. The url should have MapServer in the url.
TokarAndrii
Robert, I have got links that needed, thank you for advice... and It started work, but with them came  problems 1. with sync zoom at  different windows
map.setZoom(evt.target.__LOD.level); dont work...as at this topic Setting initial extent sets to closest zoom level in basemap
2.when first document loading it is not set different maps (my custom basemaps) at different maps but toogle works correctly.
Have you any ideas how fix it? Also can you advice me some useful recources to grow me knowledges (except js api for arcgis)
TokarAndrii
for the 1 question
    map2.setExtent(evt.extent)
 works fine but the other one need solution...
TokarAndrii
A hace got such error
Tokar,
  All baseemaps have to be in the same spatial reference and use the same LODs. I am not sure what your basemaps spatial reference is but the error is stating that it can not reproject to 4326.
