How Do I Draw Queried Geometry w/ ArcGIS JavaScript API?
2258
07-11-2016 04:29 PM
ChristopherLai
I am new to all of coding and I have a rest point with all of my park polygons, what I want to do is be able to  select a park  name from a drop down menu and query out and display the single park that is chosen. I believe I have everything set up to query my geometry, now I don't know how to get it to draw the queried feature. right now I have 2 different drop downs. According to my professor i have the 2 selections stored in "selectedParkFeature" and "selectedLayer" variable, and all I have to do now is to draw them on the map. I have researched and I am stuck, please help. I am doing all of this on ArcGIS JavaScript API 3.17.
        query("#selectParkName").on('change', function (evt) {
        var tempParkName = evt.target.value;
        getParkFeature(tempParkName);
    //function to select the park
    function getParkFeature(in_park_name) {
        var query = new Query();
        query.where = "NAME='" + in_park_name + "'";
        query.outFields = ["*"];
        park.queryFeatures(query, function (featureSet) {
            console.log(featureSet);
            selectedParkFeature = featureSet.features[0];
       query("#myPick").on('change', function (evt) {
           var tempLayerName = evt.target.value;
           chooseLayer(tempLayerName);
       function chooseLayer(inLyrName) {
           selectedLayer = map.getLayer(inLyrName);
           query.geometry = selectedParkFeature.geometry;
           selectedLayer.queryFeatures(query, function (featureSet) {
               //now you can draw these features on the map
ChrisSmith7
Honored Contributor
Christopher,
It looks like this is part of a school assignment. I would recommend you check out this:
Using QueryTask, Query, and FeatureSet | Guide | ArcGIS API for JavaScript 3.17
Specifically, I'd have a look at the "Create a function to show the results" section to see if that gives you any ideas!
