History API to track selected feature 3.x in 4.x
1295
09-24-2018 04:43 AM
ImtiyazPasha
I am trying to convert History API to track selected feature sample from 3.x into 4.x.
Please share the 4.x code, thanks in advance.
History API to track selected feature | ArcGIS API for JavaScript 3.25
RobertScheitlin__GISP
Imtiyaz,
Here is that sample using 4.8 (minus the parcel highlight):
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Parcel Locator</title>
    <link rel="stylesheet" href="http://js.arcgis.com/4.8/esri/css/main.css">
    <style>
      html, body, #map {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
    </style>
    <script>
      var dojoConfig = {
        has: {
          "esri-featurelayer-webgl": 1
    </script>
    <script src="http://js.arcgis.com/4.8/"></script>
    <script>
      var map;
      var parcels;
      require([
        "esri/Map", "esri/views/MapView", "esri/layers/FeatureLayer",
        "esri/layers/TileLayer", "esri/tasks/support/Query",
        "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol",
        "esri/Graphic", "esri/widgets/Popup",
        "esri/core/urlUtils",
        "esri/Color",
        "dojo/on", "dojo/query", "dojo/parser", "dojo/dom-construct",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        Map, MapView, FeatureLayer,
        TileLayer, Query,
        SimpleFillSymbol, SimpleLineSymbol,
        Graphic, Popup,
        urlUtils,
        Color,
        on, query, parser, domConstruct
        parser.parse();
        var popup = new Popup({
          container: domConstruct.create("div")
        var basemap = new TileLayer({url:"http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/AssessorsBasemap/MapServer"});
        map = new Map({
          layers: [basemap]
        var view = new MapView({
          container: "viewDiv",
          map: map,
          popup: popup
        //apply a popup template to the parcels layer to format popup info
        var popupTemplate = {
          title: "{PARCELID}",
          content: [{
            type: "fields",
            fieldInfos: [{
              fieldName: "SITEADDRESS",
              label: "Address:",
              visible: true
              fieldName: "OWNERNME1",
              label: "Owner:",
              visible: true
          actions: [{
            className: "esri-icon-contact",
            title: "Email Map"
        //add the parcels layer to the map as a feature layer in selection mode we'll use this layer to query and display the selected parcels
        parcels = new FeatureLayer({
          url:" http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/AssessorsBasemap/MapServer/1",
          outFields: ["*"],
          popupTemplate: popupTemplate
        view.when(function() {
          // Watch for when features are selected
          view.popup.watch("selectedFeature", function(graphic) {
            if (graphic) {
              var parcelid = graphic.attributes["PARCELID"];
              //Refresh the URL with the currently selected parcel
              if (typeof history.pushState !== "undefined") {
                window.history.pushState(null, null, "?parcelid=" + graphic.attributes.PARCELID);
          var popup = view.popup;
          popup.viewModel.on("trigger-action", function(event) {
            if (event.action.id === "Email-Map") {
              var attributes = popup.viewModel.selectedFeature.attributes;
              // Get the 'PARCELID' field attribute
              var info = attributes.PARCELID;
              // Make sure the 'PARCELID' field value is not null
              if (info) {
                var url = window.location;
                var emailLink = "mailto:?subject=Parcel Map of :" +
                  info + "&body=Check out this map: %0D%0A " +
                  window.location;
                window.location.href = emailLink;
        parcels.when(function(){
          // Add a link into the InfoWindow Actions panel
          var emailLink = domConstruct.create("a", {
            "class": "action",
            "innerHTML": "Email Map",
            "href": "javascript:void(0);"
          }, query(".actionList", view.popup.domNode)[0]);
          //When users navigate through the history using the browser back/forward buttons select appropriate parcel
          //http://developer.mozilla.org/en/DOM/Manipulating_the_browser_history
          window.onpopstate = function (event) {
            var parcelid = getParcelFromUrl(document.location.href);
            if (parcelid) {
              selectParcel(parcelid);
            } else {
              //parcels.clearSelection();
              view.popup.close();
          //if a parcelid is specified in url param select that feature
        map.add(parcels);
        //extract the parcel id from the url
        function getParcelFromUrl(url) {
          var urlObject = urlUtils.urlToObject(url);
          if (urlObject.query && urlObject.query.parcelid) {
            return urlObject.query.parcelid;
          } else {
            return null;
        //select parcel from the feature layer by creating a query to look for the input parcel id
        function selectParcel(parcelid) {
          if (parcelid) {
            var query = parcels.createQuery();
            query.where = "PARCELID = '" + parcelid + "'";
            var deferred = parcels.queryFeatures(query).then(function (selection) {
              var center = selection.features[0].geometry.extent.center;
              var extHandler = view.watch("stationary", function () {
                extHandler.remove();
                //zoom to the center then display the popup
                view.popup.open({
                  features: selection.features,
                  updateLocationEnabled: true
              view.goTo({
                target: center,
                zoom: 8
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false"
    style="width: 100%; height: 100%; margin: 0;">
      <div id="viewDiv" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
    </div>
  </body>
</html>
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Imtiyaz,
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #map {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
    </style>
    <script>
      var dojoConfig = {
        has: {
    </script>
    <script>
      var map;
      var parcels;
      require([
        "esri/Color",
      ], function(
        TileLayer, Query,
        Graphic, Popup,
        urlUtils,
        Color,
        parser.parse();
        map = new Map({
          layers: [basemap]
          map: map,
          popup: popup
          content: [{
            type: "fields",
            fieldInfos: [{
              label: "Address:",
              visible: true
              label: "Owner:",
              visible: true
          actions: [{
            title: "Email Map"
          outFields: ["*"],
            if (graphic) {
              if (info) {
                  window.location;
            "class": "action",
            if (parcelid) {
            } else {
              view.popup.close();
        map.add(parcels);
          } else {
            return null;
          if (parcelid) {
                view.popup.open({
              view.goTo({
                target: center,
                zoom: 8
    </script>
  </head>
    </div>
  </body>
</html>
ImtiyazPasha
Thanks a lot,  exactly what I was looking for.
It will be great if we add x & y and LOD to URL parameter on the zoom of the parcel.
Please extend your sample further, it will be very helpful.
Why XY? I can see adding LOD.
ImtiyazPasha
In some cases for new parcels no ID assigned, we can provide the extent of the area using  X and Y coordinates in URL.
This is untested since the layer in the same always has a parcelid.
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #map {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
    </style>
    <script>
      var map;
      var parcels;
      require([
        "esri/Color", "esri/geometry/Point",
      ], function(
        TileLayer, Query,
        Graphic, Popup,
        urlUtils,
        Color, Point,
        parser.parse();
        window.progSelection = false;
        map = new Map({
          layers: [basemap]
          map: map,
          popup: popup
        // Create a symbol for rendering the graphic
        var fillSymbol = {
          type: "simple-fill", // autocasts as new SimpleFillSymbol()
          color: [111, 0, 255, 0.3],
          outline: { // autocasts as new SimpleLineSymbol()
            color: [111, 0, 255],
            width: 1
          content: [{
            type: "fields",
            fieldInfos: [{
              label: "Address:",
              visible: true
              label: "Owner:",
              visible: true
          actions: [{
            title: "Email Map"
          outFields: ["*"],
            if (graphic) {
              view.graphics.removeAll();
              if(!window.progSelection){
                  if(!graphic.attributes.PARCELID || graphic.attributes.PARCELID === ''){
                    var cent = graphic.geometry.getCentroid();
                    window.history.pushState(null, null, "?xy=" + cent.x + "," + cent.y + '&zoom=' + view.zoom);
                  }else{
                    window.history.pushState(null, null, "?parcelid=" + graphic.attributes.PARCELID + '&zoom=' + view.zoom);
              var polygonGraphic = new Graphic({
                geometry:graphic.geometry,
                symbol: fillSymbol
              view.graphics.add(polygonGraphic);
          view.popup.watch("visible", function(visible) {
            if(visible === false){
              if (info) {
                  window.location;
              }else{
                var cent = popup.viewModel.selectedFeature.geometry.getCentroid();
                var xy = cent.x + ", " + cent.y;
                  xy + "&body=Check out this map: %0D%0A " +
                  window.location;
            "class": "action",
            var zoom = getZoomFromUrl(document.location.href);
            var xy = getXYFromUrl(document.location.href);
            if (parcelid || xy) {
              if(parcelid){
                selectParcel(parcelid, zoom);
              if(xy){
                selectParcelfromPoint(xy, zoom);
            } else {
              view.popup.close();
          if(parcelid){
          if(xy){
        map.add(parcels);
          } else {
            return null;
        //extract the zoom from the url
        function getZoomFromUrl(url) {
          if (urlObject.query && urlObject.query.zoom) {
            return urlObject.query.zoom;
          } else {
            return null;
        //extract the XY from the url
        function getXYFromUrl(url) {
          if (urlObject.query && urlObject.query.xy) {
            var xy = urlObject.query.xy.split(',');
            var pnt = new Point({
              x: xy[0],
              y: xy[1],
              spatialReference: view.spatialReference
            return pnt;
          } else {
            return null;
        //select parcel from the feature layer by creating a query to look for the input point
        function selectParcelfromPoint(point, zoom) {
          query.geometry = point;
              geometry: selection.features[0].geometry,
              symbol: fillSymbol
              window.progSelection = true;
              view.popup.open({
            view.goTo({
              target: center,
              zoom: parseInt(zoom) || 8
        function selectParcel(parcelid, zoom) {
          if (parcelid) {
                symbol: fillSymbol
                view.popup.open({
              view.goTo({
                target: center,
    </script>
  </head>
    </div>
  </body>
</html>
