Hide Representative Fraction on Print Layout JS API 3.x
1067
06-26-2019 08:03 AM
GeorgeHilton__GISP
Is there a way to hide the RF on a print map created using the JS API?  I want to display only the scale bar and hide the RF text (ex. 1:600) which appears above.
George Hilton
Town of Queensbury, NY
Noah-Sager
Hi George. I'm not sure you can do this with the JS API. I believe you would need to create and use a custom Print template published from ArcMap or ArcGIS Pro.
GeorgeHilton__GISP
Thanks Noah.  I will look into creating a custom template.
