Help with displaying results of query
2441
17
10-04-2018 06:32 AM
JohnRichardson
The query runs successfully, but I need help showing it on my map ... I want the user to select a menu option which runs the query and then displays the results on the map .... ideally adding the results to a layer list to be turned on and off if the user desires. Help?
require([
      "esri/Map",
      "esri/views/MapView",
      //"esri/views/SceneView",
      "esri/widgets/Home",
      "esri/widgets/Search",
      "esri/widgets/BasemapGallery",          //loading the necessary libraries and classes and objects from the ESRI API
      "esri/widgets/Expand",
      "esri/layers/FeatureLayer",
      "esri/layers/ImageryLayer",
      "esri/widgets/LayerList",
      "esri/tasks/QueryTask",
      "esri/tasks/support/Query",
      "esri/layers/GraphicsLayer",
      "esri/Graphic",
      "dojo/dom",
      "dojo/on",
      "dojo/domReady!"
      ],function(Map, MapView, Home, Search, BasemapGallery, Expand, FeatureLayer, ImageryLayer, LayerList, QueryTask, Query, GraphicsLayer, Graphic, dom, on) {
      var map = new Map({     //creates new empy map, with streets as basemap
      basemap: "streets",
      layers: [burgResults]
      var view = new MapView({      //creates the map view and shows the map in the mapBox container
      container: "mapBox",
      map: map,
      zoom: 13,
      center: [-85.675, 40.09],      //centers map on Anderson, Indiana
      var homewidget = new Home({     //adds the home widget to the map view
      view: view
      view.ui.add(homewidget, "top-left");
      searchWidget = new Search({     //add the search widget to the map view
      view:view,
      showInfoWindowOnSelect: false,
      popupEnabled: false,
      popupOpenOnSelect: false
      view.ui.add(searchWidget, "bottom-right");
      var basemapGallery = new BasemapGallery({     //add the basemap gallery widget to map view
      view: view
      var bgExpand = new Expand({     //puts the basemap gallery widget into an expand widget
      view: view,
      content: basemapGallery,
      collapseTooltip: "Close Basemap Gallery",
      expandTooltip: "Open Basemap Gallery"
      view.ui.add(bgExpand, "bottom-left");
      var burgSym = {                                   //creates the symbol for burglaries
           type: "simple-marker",
           color: "blue",
           style: "diamond",
      var theftSym = {                                   //creates the symbol for thefts
           color: "red",
           style: "square",
      var otherSym = {                                   //creates a default symbol
           color: "black",
           style: "circle"
      var crimeRenderer = {                              //creates the renderer for the crimes layer
           type: "unique-value",
           defaultSymbol : otherSym,
           field: "Offense",
           uniqueValueInfos: [{
                value: "Burglary",
                symbol: burgSym
                value: "Theft",
                symbol: theftSym
      var featurelayer = new FeatureLayer({      //adds a feature layer of 2018 Crime
      url: "http://172.20.25.165:6080/arcgis/rest/services/Crime2018/FeatureServer",
      title: "2018 Crime",
      renderer: crimeRenderer,
      visible: false
      map.add(featurelayer, 2);
      var orthLayer = new ImageryLayer({      //adds an image layer of Orthos SCE
      url: "http://172.20.25.165:6080/arcgis/rest/services/Ortho_SCE/ImageServer",
      title: "Ortho - East",
      visible: false
      map.add(orthLayer, 0);
      var orthLayer2 = new ImageryLayer({      //adds an image layer of Orthos SCW
      url: "http://172.20.25.165:6080/arcgis/rest/services/Ortho_SCW/ImageServer",
      title: "Ortho - West",
      visible: false
      map.add(orthLayer2, 1);
      var layerList = new LayerList({     // add a layer list to the map view
      view: view
      var llExpand = new Expand({     //puts the layer list widget into an expand widget
      view: view,
      content: layerList,
      collapseTooltip: "Close Layer List",
      expandTooltip: "Open Layer List"
      view.ui.add(llExpand, "top-right");
      var burgResults = new GraphicsLayer();
      var burgQuery = featurelayer.createQuery();                             //this section runs a query on the crimes layer, selecting burglaries
      burgQuery.where = "Offense = 'Burglary' OR Offense = 'Burg'";
      burgQuery.outFields = ["Offense" , "Location"];
      burgQuery.returnGeometry = true;
      featurelayer.queryFeatures(burgQuery)
      .then(function(results) {
            console.log(results.features);
      function displayResults(results) {
            burgResults.removeAll();
            var burgFeatures = results.features.map(function(graphic) {
            graphic.symbol = {
                  style: "triangle",
                  color: "purple"
            return graphic;
            burgResults.addMany(features);
_____
New Member
JohnRichardson
This is the error I am getting in the console :
dojo.js:956 Uncaught TypeError: Cannot read property 'parent' of undefined at Object.<anonymous> (dojo.js:956) at Object.r [as onafter-add] (dojo.js:60) at Function.h.emit (dojo.js:55) at Function.h.emit (dojo.js:56) at Object.b.emit (dojo.js:369) at Object.e._splice (dojo.js:220) at Object.e.addMany (dojo.js:208) at Object.g.referenceSetter (dojo.js:380) at Object.set (dojo.js:957) at c.set (dojo.js:247)
KenBuja
You haven't define features in this line. Should it be burgFeatures?
You've created the GraphicsLayer burgResults, but where have you added it to the map?
JohnRichardson
Thank you for answering ... that is where I am confused ... I am not sure how to add the results to the map ...
I tried burgResults.addMany(burgFeatures) just now, and still getting the same error
KenBuja
Actually, now I see where you are adding burgResults to the map. It's up where the map is created.
  basemap: "streets",
You're trying to use it before you have defined it.
JohnRichardson
Thank you again ...
Is there a way to add it to the map where it is?
In other instances I used map.add ... is there something similar for graphics layers?
JohnRichardson
I removed "layers: [burgResults] and included map.add(burgResults) at the bottom ... still the layer does not draw on the map ... no errors, just no display on the map
Thanks!
_____
New Member
JohnRichardson
Still no go ...no errors, but still no display
Here is what the code looks like now ...
require([
      "esri/Map",
      "esri/Graphic",
      "esri/geometry/SpatialReference",
      "dojo/dom",
      "dojo/on",
      "dojo/domReady!"
      ],function(Map, MapView, Home, Search, BasemapGallery, Expand, FeatureLayer, ImageryLayer, LayerList, QueryTask, Query, GraphicsLayer, Graphic, SpatialReference, dom, on) {
      basemap: "streets",
      /*layers: [burgResults]*/
      map: map,
      zoom: 13,
      view: view
      view:view,
      view: view
      view: view,
           color: "blue",
           style: "diamond",
           color: "red",
           style: "square",
           color: "black",
           style: "circle"
           field: "Offense",
                value: "Burglary",
                symbol: burgSym
                value: "Theft",
                symbol: theftSym
      visible: false
      visible: false
      visible: false
      view: view
      view: view,
      content: layerList,
      var sr = new SpatialReference(102100);
      burgQuery.outSpatialReference = sr;
            graphic.symbol = {
                  style: "triangle",
                  color: "purple"
            return graphic;
            burgResults.addMany(burgFeatures);
            map.add(burgResults);
_____
New Member
