help configuring Intern w/ ArcGIS API for JavaScript
2895
01-24-2016 04:59 PM
JohnCartwright
Hello All,
I'm trying to configure Intern to do some unit testing on some legacy ArcGIS Javascript projects.  I'm having trouble understanding the "loader" configuration in intern.js, e.g.
        loaders: {
                'host-node': 'bower_components/dojo/dojo',
                'host-browser': 'node_modules/dojo/dojo.js'
I'm working off examples from SitePen​, David Spriggs​, and Rene's Yeoman generator​, but don't seem to be able to get all the pieces to work together.  My objective is pretty simple: get the SitePen tutorial working using the Esri-version of dojo provided by Bower.
I don't really understand why the "loaders" configuration is required to provide a dojo other than the default but that's done in both the Esri-related examples.  In my case​ when I configure the loaders config as above, I get the error:
    Error: Cannot find module 'bower_components/dojo/dojo'
    at Function.Module._resolveFilename  <module.js:339:15>
    at Function.require.resolve  <internal/module.js:23:19>
    at <node_modules/intern/lib/executors/PreExecutor.js:437:32>
    at new Promise  <node_modules/intern/node_modules/dojo/Promise.ts:411:3>
    at PreExecutor.swapLoader  <node_modules/intern/lib/executors/PreExecutor.js:428:11>
    at swapLoader  <node_modules/intern/lib/executors/PreExecutor.js:389:17>
    at <node_modules/intern/node_modules/dojo/Promise.ts:393:15>
    at runCallbacks  <node_modules/intern/node_modules/dojo/Promise.ts:11:11>
    at <node_modules/intern/node_modules/dojo/Promise.ts:317:4>
    at run  <node_modules/intern/node_modules/dojo/Promise.ts:237:7>
There is a bower_components/dojo/dojo.js file.
Any help or clarification would be much appreciated!
--john
Tags (3)
