Gibco basemap not being visualized
1209
07-18-2018 11:40 PM
kishorekumar1
Dear Sir,
                      I was using the Gibco basemap with the url: "https://maps.ngdc.noaa.gov/arcgis/rest/services/web_mercator/gebco_2014_hillshade/MapServer"   as my basemap in our applciation which is developed using "ArcGIS api for javascript ".But now i am not able to view the basemap. But,when i view the service in arcgis online i am able to view the Gibco basemap.But it is failing using arcgis api for javascript. Can any one help me in this regard
Regards,
Kishore Kumar
KenBuja
MVP Esteemed Contributor
Can you post your code?
kishorekumar1
Dear Ken,
                      Below I am posting my code.Kindly refer it.
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>Simple Map</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.25/esri/css/esri.css">
<style>
html, body, #map {
height: 100%;
margin: 0;
padding: 0;
</style>
<script src="https://js.arcgis.com/3.25/"></script>
<script>
var map;
require(["esri/map","esri/dijit/Basemap",
"esri/dijit/BasemapLayer", "dojo/domReady!"], function(Map,Basemap, BasemapLayer) {
var lyrGEBCO = new BasemapLayer(
{ url : "https://maps.ngdc.noaa.gov/arcgis/rest/services/web_mercator/gebco_2014_hillshade/MapServer"
//url : "https://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"
var bmapGEBCO = new Basemap ({ layers : [ lyrGEBCO ],
title : "GEBCO",
thumbnailUrl : "images/mgs_gebco.png"
map = new Map("map", {
basemap: bmapGEBCO, //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
center: [-122.45, 37.75], // longitude, latitude
zoom: 13
</script>
</head>
<body>
<div id="map"></div>
</body>
</html>
Regards,
Kishore Kumar
KenBuja
You cannot use a dynamic service as a basemap in the map constructor. This code works for tiled services
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <style>
    html,
    body,
    #map {
      height: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script>
    var map;
    require(["esri/map", "esri/basemaps", "dojo/domReady!"], function (Map, esriBasemaps) {
      //var lyrGEBCO = new BasemapLayer(
      //{ url : "https://maps.ngdc.noaa.gov/arcgis/rest/services/web_mercator/gebco_2014_hillshade/MapServer"
      //var bmapGEBCO = new Basemap ({ layers : [ lyrGEBCO ],
      //title : "GEBCO",
      //thumbnailUrl : "images/mgs_gebco.png"
      // esriBasemaps.gebco = {
      //   baseMapLayers: [{ url: "https://maps.ngdc.noaa.gov/arcgis/rest/services/web_mercator/gebco_2014_hillshade/MapServer"}
      //   thumbnailUrl: "https://www.example.com/images/thumbnail_2014-11-25_61051.png",
      //   title: "GEBCO"
      // map = new Map("map", {
      //   basemap: gebco, //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
      //   center: [-122.45, 37.75], // longitude, latitude
      //   zoom: 13
        baseMapLayers: [{ url: "https://services.arcgisonline.com/ArcGIS/rest/services/Specialty/DeLorme_World_Base_Map/MapServer" }
        title: "Delorme"
      var map = new Map("map", {
        basemap: "gebco",
        center: [-111.879655861, 40.571338776], // long, lat
        zoom: 13,
        sliderStyle: "small"
  </script>
</head>
<body>
</body>
</html>
Take a look at this post for one way to use a dynamic service in the Basemap Gallery
KenBuja
That service also doesn't appear to be showing anything. It's not getting visualized in the AGOL Map Viewer
