Get new point coordinate by current Point coordinate, angle and distance
6105
8
07-20-2021 07:57 AM
mohameantar
Hello all,
i want to create new point to be away by specific angle and distance from existing point .
i checked geometryEngine.offset but its working only for polyline or polygon not working for points also i need to control the angle so i create the new point up or down not only right and left.
Thank you all
AndyGup
I have some code that uses latitude and longitude as input values to calculate a second point based on bearing and distance. Haven't used this in quite a while. I'm not sure how much efficiency you need, you would have handle any additional coordinate conversions:
        function bearingDistance(lat, lon, radius, bearing){
          const lat1Rads = toRad(lat);
          const lon1Rads = toRad(lon);
          const R_KM = 6371; // radius in KM
          const d = radius/R_KM; //angular distance on earth's surface
          const bearingRads = toRad(bearing);
          const lat2Rads = Math.asin(
            Math.sin(lat1Rads) * Math.cos(d) + Math.cos(lat1Rads) * Math.sin(d) * Math.cos(bearingRads)
          const lon2Rads = lon1Rads + Math.atan2(
            Math.sin(bearingRads) * Math.sin(d) * Math.cos(lat1Rads),
            Math.cos(d) - Math.sin(lat1Rads) * Math.sin(lat2Rads)
          return {
            latitude: toDeg(lat2Rads),
            longitude: toDeg(lon2Rads)
        function toRad(degrees){
          return degrees * Math.PI / 180;
        function toDeg(radians){
          return radians * 180 / Math.PI;
AndyGup
          return {
JayakumarPD
Hi sir, we are using the same code as given but getting the point at a wrong distance, kindly help us how to get the new point at given distance.
For lat- lattittue
       log- logitude
       radius- distance we are passing(line distance)
       bearing- angle
if we enter 200 mt distance, the line length will be 652 mt.  How to get the new point at the exact line distance, which we are providing.  The screen shot provided for reference.
AndyGup
JayakumarPD
thank you sir,
mohameantar
its working, thank you exactly what i want 😀
JohnGrayson
Esri Alum
You can also try the pointFromDistance() method: Geodetically computes the location at a defined distance and direction from a known location.
NiklasKöhn
Hi @JohnGrayson @AndyGup,
it's been a while since the pointFromDistance() hint, and the geodesicUtils have been deprecated in JSSDK v 4.33, and I can't seem to find an operator that solves this very problem. Am I missing something?
Nik
AndyGup
@NiklasKöhn  thanks for the feedback. Correct, there's currently no replacement for pointFromDistance(). We are looking into options for that.
