geometryService.lengths() is not working on the 4.8
1358
09-20-2018 07:57 AM
RN
Hello,
I've take the code from here :
ArcGIS API for JavaScript Sandbox
And i've added this code
var lengthParamsCliped = new LengthsParameters();
lengthParamsCliped.calculationType = 'geodesic';
lengthParamsCliped.geodesic = true;
lengthParamsCliped.lengthUnit = 'METER';
lengthParamsCliped.polylines = [polyline];
geometryService.lengths(lengthParamsCliped).then(calculatedClippedLength);
function calculatedClippedLength(res)
console.info(res);
The code stop with the message "a.toJSON is not a function"
Where a is the polyline who looks like that:
  1. a: Object
    1. pathsArray(3)
      1. 0Array(2)
        1. 0-111.3
        2. 152.68
        3. length2
        4. __proto__Array(0)
      2. 1Array(2)
        1. 0-98
        2. 149.5
        3. length2
      3. 2Array(2)
        1. 0-93.94
        2. 129.89
        3. length2
      4. length3
      5. __proto__Array(0)
    2. spatialReference:
      1. wkid4326
      2. __proto__Object
    3. type"polyline"
    4. __proto__Object
I will be grateful if someone could help me to find a solution.
Thanks in advance
Best regards
RN
#geometryService
#lengths()
#4.8
#4.x
#a.toJSON
RobertScheitlin__GISP
R N,
   The doc is not very clear when it say a string or number for the length unit it is expecting the numeric value of the unit as a number or a string. METER = 9001
lengthParamsCliped.lengthUnit = 9001;
RN,
  The LengthsParameters class does not autoCast the values of the polylines property to actual PolyLines. So you have to give it an array of ACTUAL polylines, not json representing Polylines.
      // First create a line geometry (this is the Keystone pipeline)
      var polyline = new Polyline({
        type: "polyline",
        paths: [
          [-111.30, 52.68],
          [-98, 49.5],
          [-93.94, 29.89]
RN
Ok i've done that and its better because i dont have any errors but unfortunaly i dont have any result at all.
Im using a simple code like that just to understand how i can mesure the lenght of a polyline.
Please take a look here:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Intro to graphics - 4.8</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.8/esri/css/main.css">
<script src="https://js.arcgis.com/4.8/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/tasks/GeometryService",
"esri/tasks/support/LengthsParameters",
"esri/geometry/SpatialReference",
"esri/geometry/Polyline",
"esri/Graphic",
"dojo/domReady!"
], function(
Map, MapView, GeometryService, LengthsParameters, SpatialReference, Polyline, Graphic
var map = new Map({
basemap: "topo"
var view = new MapView({
center: [-80, 35],
container: "viewDiv",
map: map,
zoom: 3
var geometryService = new GeometryService('http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/Geometry/GeometryServer');
* Create a polyline graphic
type: "polyline",
paths: [
[-111.30, 52.68],
[-98, 49.5],
[-93.94, 29.89]
spatialReference: { wkid: 4326 }
// Create a symbol for drawing the line
var lineSymbol = {
type: "simple-line", // autocasts as SimpleLineSymbol()
color: [226, 119, 40],
width: 4
var polylineGraphic = new Graphic({
geometry: polyline,
symbol: lineSymbol
view.graphics.add(polylineGraphic);
// try to find the lenght of a polyline
var myLongueur;
geometryService.lengths(lengthParamsCliped).then(function (calculatedClippedLength) {
if (calculatedClippedLength.lengths.length > -1) {
myLongueur = calculatedClippedLength.lengths[0];
console.info(myLongueur);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
R N,
RN
You have make my weekend better, i've tried so hard to find a solution and i've knew it was something little to find.
Best regards
RN
