The result of the CreateReport method is a binary byte-stream where the PDF or Excel report are returned directly. The calling application will have to handle the response and present and/or save the binary output.
Identify the latest downloaded file from the downloads folder and then open in a browser by using
window.open method in Javascript..
Cheers,Srikanth Dasari
Alternatively, you can use the blob type with your esriRequest like this (it will download the file and the user can click to open in browser):
<SPAN class="token function">esriRequest</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> handleAs<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'blob'</SPAN><SPAN class="punctuation token">,</SPAN> content<SPAN class="punctuation token">:</SPAN> myArgs<SPAN class="punctuation token">,</SPAN> url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fgeoenrich.arcgis.com%2Farcgis%2Frest%2Fservices%2FWorld%2Fgeoenrichmentserver%2Fgeoenrichment%2Fcreatereport" target="_blank">https://geoenrich.arcgis.com/arcgis/rest/services/World/geoenrichmentserver/geoenrichment/createreport</A><SPAN>'</SPAN></SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>response <SPAN class="keyword token">instanceof</SPAN> <SPAN class="token class-name">Blob</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> blob <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Blob</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>response<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'application/pdf'</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>navigator<SPAN class="punctuation token">.</SPAN>msSaveBlob<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// IE 10+</SPAN> navigator<SPAN class="punctuation token">.</SPAN><SPAN class="token function">msSaveBlob</SPAN><SPAN class="punctuation token">(</SPAN>blob<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'myfile.pdf'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> link <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createElement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"a"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> url <SPAN class="operator token">=</SPAN> URL<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createObjectURL</SPAN><SPAN class="punctuation token">(</SPAN>blob<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> link<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setAttribute</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"href"</SPAN><SPAN class="punctuation token">,</SPAN> url<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>link<SPAN class="punctuation token">.</SPAN>download <SPAN class="operator token">!==</SPAN> undefined<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// feature detection</SPAN> <SPAN class="comment token">// Browsers that support HTML5 download attribute</SPAN> link<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setAttribute</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"download"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>fileName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> link<SPAN class="punctuation token">.</SPAN>style <SPAN class="operator token">=</SPAN> <SPAN class="string token">"visibility:hidden"</SPAN><SPAN class="punctuation token">;</SPAN> document<SPAN class="punctuation token">.</SPAN>body<SPAN class="punctuation token">.</SPAN><SPAN class="token function">appendChild</SPAN><SPAN class="punctuation token">(</SPAN>link<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> link<SPAN class="punctuation token">.</SPAN><SPAN class="token function">click</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> document<SPAN class="punctuation token">.</SPAN>body<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeChild</SPAN><SPAN class="punctuation token">(</SPAN>link<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
