If I make a call like this in JS how to I capture the result IN JS and parse through it and set variables for the Match_addr and X and Y
findAddressCandidates—ArcGIS REST API: World Geocoding Service | ArcGIS for Developers
http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer/findAddressCandidates?SingleLine=380%20New%20York%20Street%2C%20Redlands%2C%20CA%2092373&category=&outFields=*&forStorage=false&f=pjson
Solved! Go to Solution.
Jay,
You would use the esriRequest class for this.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Request data from a remote server - 4.6</title>
<style>
html,
body,
#viewDiv {
font-family: sans-serif;
padding: 0;
margin: 0;
height: 100%;
width: 100%;
.container {
padding: 1em;
input {
width: 75%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.14/esri/css/main.css">
<script src="https://js.arcgis.com/4.14/"></script>
<script>
require([
"esri/request",
"dojo/on",
"esri/config",
"dojo/domReady!"
], function(
esriRequest,
on,
esriConfig
esriConfig.request.proxyUrl = 'proxy/proxy.ashx';
var resultsDiv = document.getElementById("resultsDiv");
var input = document.getElementById("inputUrl");
* Define the 'options' for our request.
var options = {
query: {
SingleLine: input.value,
outFields: "*",
forStorage: false,
f: 'pjson'
responseType: 'json'
// Make the request on a button click using the
// value of the 'input' text.
on(btnQuery, "click", function() {
var url = 'http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer/findAddressCandidates';
esriRequest(url, options).then(function(response) {
console.log('response', response);
var responseJSON = JSON.stringify(response, null, 2);
resultsDiv.innerHTML = responseJSON;
</script>
</head>
<body>
<div class="container">
<div>
<h2>Using esri/request</h2>
<button id="btnQuery">Make Request</button>
<input id="inputUrl" type="text" value="380 New York St, Redlands, California, 92373">
</div>
<pre id="resultsDiv"></pre>
</div>
</body>
</html>
Jay,
<!DOCTYPE html>
<html>
<head>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
.container {
padding: 1em;
input {
width: 75%;
</style>
<script>
require([
"esri/request",
"dojo/on",
"esri/config",
"dojo/domReady!"
], function(
esriRequest,
on,
esriConfig
var options = {
query: {
outFields: "*",
forStorage: false,
f: 'pjson'
</script>
</head>
<body>
<div>
</div>
</div>
</body>
</html>
Fantastic....had to modify your code a bit, placing the var options= {} inside the click event in order to get it to read my input box contained the address to geocode... just a different workflow as I am not defaulting my address
THANK YOU FOR YOUR INSIGHT AND HELP.....very appreciated.
/* SNIP */
<div>
<button class="button" id="btnQuery1" onclick="myFunction_Geocode()" >Populate Address</button>
<input id="inputUrl" name="esrirequest" type="text" value="" >
<input id="esriresult" name="esriresult" type="text" >
<button class="button" id="btnQuery2">Make Request</button>
</div>
<pre id="resultsDiv" class="resultsdivgeocode"></pre>
/* SNIP */
// SNIP
// Make the request on a button click using the value of the 'inputUrl' text.
on(btnQuery2, "click", function () {
var requestinputvalue = input.value;
var options = {
query: {
SingleLine: requestinputvalue,
outFields: "*",
forStorage: false,
f: 'pjson'
alert(JSON.stringify(options));
esriRequest(url, options).then(function (response) {
// ALERT COMPLETE JSON RESPONCE FOR GEOCODING
alert(JSON.stringify(response));
// ADDRESS
var address = response.data.candidates[0].address;
// X COORDINATE
var vXCoord = JSON.stringify(response.data.candidates[0].location.x);
// Y COORDINATE
var vYCoord = JSON.stringify(response.data.candidates[0].location.y);
// RETURN COMPLETE JSON FILE WITH GEOCODIN RESULTS
// CREATE ARRAY FROM ADDRESS AND SPLIT INTO VARIABLES
var array = address.split(',', 4);
var array0 = (array[0]);
var array1 = (array[1]);
var array2 = (array[2]);
var array3 = parseInt(array[3]);
// UPDATE WEB PAGE INPUT BOXES
document.getElementsByName('idstreet')[0].value = (array0);
document.getElementsByName('idcity')[0].value = (array1);
document.getElementsByName('idstate')[0].value = (array2);
document.getElementsByName('idzip')[0].value = (array3);
document.getElementsByName('idx')[0].value = vXCoord;
document.getElementsByName('idy')[0].value = vYCoord;
// SNIP
