FeatureTable events for cell selection and hover
2247
07-08-2019 07:45 AM
Buckler_Tom
I'm using the JS API 3.29 and a FeatureTable. I would like to be able to fire events on individual cells rather than an entire row. But the only documented events are for entire rows. I found this thread where Robert Scheitlin, GISP suggested using an event based on the grid's header using mouseover, but I can't get any events like that to work, using the headers or cells or anything. Does it have something to do with using a FeatureTable rather than a base Dojo dgrid?
RobertScheitlin__GISP
Tom,
   You can do the same thing with a FeatureTable.
          on(myFeatureTable, "load", function(evt){
            myFeatureTable.grid.on("th.field-Spp_Code:mouseover", function(){
              console.info("hover");
              //do your tooltip here
Tom,
Buckler_Tom
Ah ok, because the grid (a dgrid) is a property of the FeatureTable. That makes sense. Thank you!
