Feature Service will not query
1760
6
06-24-2022 01:37 PM
JohnnyHarley12
Hello, I have a map that does everything I want except query successfully.. I am assuming that one of my functions are out of place because the query pane is showing 0 results in my query. My data source is a feature service from Fulcrum.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>QueryTask - 4.12</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
#optionsDiv {
background-color: dimgray;
color: white;
padding: 10px;
width: 350px;
.esri-popup .esri-popup-header .esri-title {
font-size: 18px;
font-weight: bolder;
.esri-popup .esri-popup-body .esri-popup-content {
font-size: 14px;
</style>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.12/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.12/"></script>
<script>
require([
"esri/config",
"esri/Map",
"esri/views/MapView",
"esri/layers/GraphicsLayer",
"esri/tasks/QueryTask",
"esri/tasks/support/Query"
], function(esriConfig,Map, MapView, GraphicsLayer, QueryTask, Query) {
// URL to feature service containing points representing the 50
// most prominent peaks in the U.S.
esriConfig.apiKey = "AAPK70505a08690e47cdabb8cc6e755833746AwLs_vRPMwQYe0qDPJfzpaVuajxLoiLFsr-GV5ZQdlXM-bRNXIOjGOvXqDgYWr8";
var peaksUrl =
"https://fulcrumapp.io/share/5529251078a50e77a26b/geoservices/FeatureServer/0";
// Define the popup content for each result
var popupTemplate = {
// autocasts as new PopupTemplate()
title: "{si_sn_id}",
fieldInfos: [
fieldName: "_status",
label: "Inspection Status",
fieldName: "structure_type",
label: "Structure Type",
fieldName: "sn_user17cd",
label: "Component Type",
fieldName: "si_dt_insp",
label: "Inspection Date",
format: {
dateFormat: "long-month-day-year"
content:
"<br><b>Inspection Status:</b> {_status}" +
"<br><b>Struture Type:</b> {structure_type} | {sn_user17cd}" +
"<br><b>Inspection Date:</b> {si_dt_insp}"
const mtnSymbol = {
type: "SimpleMarkerSymbol",
symbolLayers: [
type: "object",
resource: {
primitive: "point"
// Create graphics layer and symbol to use for displaying the results of query
var resultsLayer = new GraphicsLayer();
* Point QueryTask to URL of feature service
var qTask = new QueryTask({
url: peaksUrl
* Set the query parameters to always return geometry and all fields.
* Returning geometry allows us to display results on the map/view
var params = new Query({
returnGeometry: false,
outFields: ["*"]
var map = new Map({
basemap: "hybrid",
layers: [resultsLayer] // add graphics layer to the map
var view = new MapView({
map: map,
container: "viewDiv",
center: [-100, 38],
zoom: 4,
popup: {
dockEnabled: true,
dockOptions: {
position: "top-right",
breakpoint: false
// Call doQuery() each time the button is clicked
view.when(function() {
view.ui.add("optionsDiv", "bottom-right");
document.getElementById("doBtn").addEventListener("click", doQuery);
var attributeName = document.getElementById("attSelect");
var expressionSign = document.getElementById("signSelect");
var value = document.getElementById("valSelect");
var attributeName2 = document.getElementById("attSelect2");
var expressionSign2 = document.getElementById("signSelect2");
var value2 = document.getElementById("valSelect2");
// Executes each time the button is clicked
function doQuery() {
// Clear the results from a previous query
resultsLayer.removeAll();
* Set the where clause for the query. This can be any valid SQL expression.
* In this case the inputs from the three drop down menus are used to build
* the query. For example, if "Elevation", "is greater than", and "10,000 ft"
* are selected, then the following SQL where clause is built here:
* params.where = "ELEV_ft > 10000";
* ELEV_ft is the field name for Elevation and is assigned to the value of the
* select option in the HTML below. Other operators such as AND, OR, LIKE, etc
* may also be used here.
params.where = attributeName.value + expressionSign.value + value.value;
// executes the query and calls getResults() once the promise is resolved
// promiseRejected() is called if the promise is rejected
qTask
.execute(params)
.then(getResults)
.catch(promiseRejected);
// Called each time the promise is resolved
function getResults(response) {
// Loop through each of the results and assign a symbol and PopupTemplate
// to each so they may be visualized on the map
var peakResults = response.features.map(function(feature) {
// Sets the symbol of each resulting feature to a cone with a
// fixed color and width. The height is based on the mountain's elevation
feature.symbol = {
type: "simple-marker",
color: "blue",
feature.popupTemplate = popupTemplate;
return feature;
resultsLayer.addMany(peakResults);
// animate to the results after they are added to the map
view.goTo(peakResults).then(function() {
view.popup.open({
features: peakResults,
featureMenuOpen: true,
updateLocationEnabled: true
// print the number of results returned to the user
document.getElementById("printResults").innerHTML =
peakResults.length + " results found!";
// Called each time the promise is rejected
function promiseRejected(error) {
console.error("Promise rejected: ", error.message);
</script>
</head>
<body>
<div id="viewDiv"></div>
<div class="esri-widget" id="optionsDiv">
<h2>Inspection Status by Structure</h2>
<select class="esri-widget" id="attSelect">
<option value="_status">Inspection Status</option>
</select>
<select class="esri-widget" id="signSelect">
<option value="=">is equal to</option>
</select>
<select class="esri-widget" id="valSelect">
<option value="Needs Inspection">Needs Inspection</option>
<option value="TREKK360 Scan Complete">TREKK360 Scan Complete</option>
<option value="2">Surface</option>
<option value="3">Not Inspected</option>
<option value="4">Buried</option>
</select>
<br />
<br />
<button class="esri-widget" id="doBtn">Do Query</button> <br />
<p><span id="printResults"></span></p>
</div>
</body>
</html>
KenBuja
I believe it's missing quotes in your params.where string. When I tested it, it comes up as
'_status=Needs Inspection'
That should be
'_status="Needs Inspection"'
As a note, when posting code, use the Insert code tool. It makes reading it much easier.
JohnnyHarley12
Ken,
  Thank you for the reply. are you saying that single quotes need to be placed in the <Body> option value portion of the code or in the actual params.where clause? I did this and no luck
      </select>
        <option value='"Needs Inspection"'>Needs Inspection</option>
        <option value='"TREKK360 Scan Complete"'>TREKK360 Scan Complete</option>
        <option value='"2"'>Surface</option>
        <option value='"3"'>Not Inspected</option>
        <option value='"4"'>Buried</option>
      </select>
KenBuja
It could either done that way or altering the where statement using template literals
params.where = `${attributeName.value} ${expressionSign.value} "${value.value}"`;
However, since I can't access the actual service, I can't run the query to see if it's working properly. Can you go into the service and run the query on the REST query page to make sure it's working?
JohnnyHarley12
My service is a feature service coming from Fulcrum and not ArcOnline. When you paste this URL in your web browser, you will just see JSON displayed. Does it matter the source is coming from Fulcrum?
https://fulcrumapp.io/share/23874ac78e7eb9ff48d4/geoservices/FeatureServer/0
KenBuja
Esri feature services should have a page like this where you can test your query:
https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3/query
I am not familiar with Fulcrum services and what their capabilities include.
Noah-Sager
The QueryTask is designed to work with an ArcGIS Server. If you look at the network traffic, does the payload and response look correct?
Also, if you're using version 4.12 of the ArcGIS API for JavaScript, why are you using an API key? API keys were not introduced to the API until version 4.18:
https://developers.arcgis.com/javascript/latest/api-reference/esri-config.html#apiKey
