Dear all,
I have a feature layer consisting of poly-lines. When I clicked on any polyline, it displayed successfully a tooltip panel containing its details in Google Chrome.
But, that doesn't work in IE 11.
How can I resolve this issue? Please guide me.
Solved! Go to Solution.
I had some problems with IE on other non-related issues. I added the below meta text to the head section of the HTML file to force IE to use an older version of IE instead of 11. Maybe it will help you.
<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE9" />
Muhammad,
Can you provide a sample that demos this issue for testing?
"meta" tag helps in resolving the issue of tooltip control.
But, after applying meta tag, saving new polyline by using webservice is not working now in IE 11.
Following error is coming now:
Error: esri.config.defaults.io.proxyUrl is not set. If making a request to a CORS enabled server, please push the domain into esri.config.defaults.io.corsEnabledServers.
You can try setting the tag to 10 instead of 9 to see if it solves both your problems. You may need to set up a proxy when using IE9, see below.
Muhammad,
Did you have a meta tag in your code for X-UA-Compatible before this? I normally have a meta tag of
<meta http-equiv="X-UA-Compatible" content="IE=edge" />
And this is only important if your organization has set IE to run in comparability mode or force comparability mode when using intra net sites.
