I'm using React [^17.0.1] and arcgis-js-api [^4.18.1] for the app,
After 'npm start' I'm receiving the below errors,
[esri.widgets.Widget] widget-intl:locale-error esri.widgets.Attribution TypeError: t is not a constructor
[esri.widgets.Widget] widget-intl:locale-error esri.widgets.Zoom TypeError: t is not a constructor
[esri.widgets.Widget] widget-intl:locale-error esri.widgets.Popup TypeError: t is not a constructor
[esri.Basemap] #load() Failed to load basemap (title: 'Basemap', id: 'gray-vector') TypeError: t is not a constructor
Zoom.js:5 Uncaught (in promise) TypeError: Cannot read property 'zoomIn' of null
Code:
import React, { useState, useRef, useEffect } from 'react';
import { Card, CardBody, CardTitle } from 'reactstrap';
import ArcGISMap from '@arcgis/core/Map';
import MapView from '@arcgis/core/views/MapView';
import esriConfig from '@arcgis/core/config';
import '../../assets/css/map.css';
const SalesChartCard = () => {
esriConfig.assetsPath = '../node_modules/@arcgis/core/assets';
const mapDiv = useRef(null);
useEffect(() => {
if (mapDiv.current) {
* Initialize application
const map = new ArcGISMap({
basemap: 'gray-vector',
/* eslint-disable no-unused-vars */
const view = new MapView({
map,
container: mapDiv.current,
extent: {
spatialReference: {
wkid: 102100,
xmax: -13581772,
xmin: -13584170,
ymax: 4436367,
ymin: 4435053,
/* eslint-enable no-unused-vars */
const [isInFullScreen, setIsInFullScreen] = useState(false);
const isInFullScreenFn = () => {
return (
(document.fullscreenElement && document.fullscreenElement !== null) ||
(document.webkitFullscreenElement &&
document.webkitFullscreenElement !== null) ||
(document.mozFullScreenElement &&
document.mozFullScreenElement !== null) ||
(document.msFullscreenElement && document.msFullscreenElement !== null)
const toggleFullScreen = () => {
const isFS = isInFullScreenFn();
const docElm = document.documentElement;
if (!isFS) {
if (docElm.requestFullscreen) {
docElm.requestFullscreen();
} else if (docElm.mozRequestFullScreen) {
docElm.mozRequestFullScreen();
} else if (docElm.webkitRequestFullScreen) {
docElm.webkitRequestFullScreen();
} else if (docElm.msRequestFullscreen) {
docElm.msRequestFullscreen();
} else if (document.exitFullscreen) {
document.exitFullscreen();
} else if (document.webkitExitFullscreen) {
document.webkitExitFullscreen();
} else if (document.mozCancelFullScreen) {
document.mozCancelFullScreen();
} else if (document.msExitFullscreen) {
document.msExitFullscreen();
setIsInFullScreen(!isFS);
return (
<Card>
<button
className="position-absolute card-top-buttons header-icon btn btn-empty d-none d-sm-inline-block"
type="button"
id="fullScreenButton"
onClick={toggleFullScreen}
{isInFullScreen ? (
<i className="simple-icon-size-actual d-block" />
<i className="simple-icon-size-fullscreen d-block" />
</button>
<CardBody>
<CardTitle>Map</CardTitle>
<div className="mapDiv" ref={mapDiv} />
</CardBody>
</Card>
export default SalesChartCard;
package.json
"scripts": {
"start": "react-scripts start",
"build": "react-scripts build",
"test": "react-scripts test",
"eject": "react-scripts eject",
"lint": "eslint .",
"lint:fix": "eslint . --fix",
"precommit": "lint-staged",
"copy": "ncp ./node_modules/@arcgis/core/assets ./public/assets",
"postinstall": "npm run copy"
I tried the solution mentioned in this post
