edits-complete event of feature layer is not firing after moving a feature
8164
7
02-09-2015 11:05 AM
AzizaParveen2
ArcGIS JavaScript API issue, I am developing a web editing application and if I move any feature,  edits-complete event of feature
layer does not fire, I need to run a function feature move/update completes. Is it a bug or I am missing something here, if you guys know any work around or having same issue please let me know.
Thanks
Aziza
ReneRubalcava
Honored Contributor
Check out this sample.
When you are done moving the vertices, you need to deactivate the toolbar. You'll need to wire up when this happens, in this case the sample deactivates the toolbar on a dbl-click and then applies the edits to the FeatureLayer.
function initEditing(evt) {
  var firePerimeterFL = map.getLayer("firePerimeterFL");
  var editToolbar = new Edit(map);
  editToolbar.on("deactivate", function(evt) {
    if ( evt.info.isModified ) {
      firePerimeterFL.applyEdits(null, [evt.graphic], null);
  var editingEnabled = false;
  firePerimeterFL.on("dbl-click", function(evt) {
    event.stop(evt);
    if (editingEnabled === false) {
      editingEnabled = true;
      editToolbar.activate(Edit.EDIT_VERTICES , evt.graphic);
    } else {
      editToolbar.deactivate();
Hope that helps.
ReneRubalcava
Honored Contributor
Do you have some sample code to get a better idea of what's happening?
Are you using the Edit Toolbar?
The edits-complete method is only emitted from a FeatureLayer after you use the applyEdits method.
AzizaParveen2
Hi Rene, Thank you so much for your response. I am not using applyEdits since I am using editor widget.
Yes I am using the toolbar but it also happens if I just click on the feature and move it. This event firs just fine if I add a new feature or delete one. Here is the sample code
Hydrants.on("edits-complete", refreshLayer);
CPN.on("edits-complete", refreshLayer);
Street.on("edits-complete", refreshLayer);
refreshLayer = function () {
webEditedLayers.refresh();
CPN.refresh();
Hydrants.refresh();
Street.refresh();
If it only works when using applyEdits, then is there any other event fire after moving a feature?
Thanks and I really appreciate your help.
ReneRubalcava
Honored Contributor
    event.stop(evt);
    } else {
Hope that helps.
AzizaParveen2
Thanks so much Rene, I got it to work from your suggestion, I was using editor widget instead of coding for editing, editor toolbar activates when you single click on a feature and deactivates when any feature gets unselected or you click any place on the map other than features and then edits-completes fires..thanks so much for pointing me to the right direction.
Regards
Aziza
JakeSkinner
Esri Esteemed Contributor
Hi Aziza,
This should work.  Below is a modified sample that writes the array of results returned from the edits-complete event after the waterbodies feature layer is edited.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Edit rivers and waterbodies</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/esri/css/esri.css" />
    <style>
      html,body{height:100%;width:100%;margin:0;overflow:hidden;}
      #map{
        padding:0;
      #header{
        font-size: 1.1em;
        font-family: sans-serif;
        padding-left: 1em;
        padding-top:4px;
        color:#660000;
      .templatePicker {
        border: none;
      .dj_ie .infowindow .window .top .right .user .content { position: relative; }
      .dj_ie .simpleInfoWindow .content {position: relative;}
    </style>
    <script src="http://js.arcgis.com/3.12/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/tasks/GeometryService",
        "esri/toolbars/edit",
        "esri/layers/ArcGISTiledMapServiceLayer",
        "esri/layers/FeatureLayer",
        "esri/Color",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/dijit/editing/Editor",
        "esri/dijit/editing/TemplatePicker",
        "esri/config",
        "dojo/i18n!esri/nls/jsapi",
        "dojo/_base/array", "dojo/parser", "dojo/keys",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
        "dojo/domReady!"
      ], function(
        Map, GeometryService, Edit,
        ArcGISTiledMapServiceLayer, FeatureLayer,
        Color, SimpleMarkerSymbol, SimpleLineSymbol,
        Editor, TemplatePicker,
        esriConfig, jsapiBundle,
        arrayUtils, parser, keys
        parser.parse();
        // snapping is enabled for this sample - change the tooltip to reflect this
        jsapiBundle.toolbars.draw.start = jsapiBundle.toolbars.draw.start +  "<br>Press <b>ALT</b> to enable snapping";
        // refer to "Using the Proxy Page" for more information:  https://developers.arcgis.com/javascript/jshelp/ags_proxy.html
        esriConfig.defaults.io.proxyUrl = "/proxy/";
        //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications.
        esriConfig.defaults.geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        map = new Map("map", {
          basemap: "satellite",
          center: [-96.541, 38.351],
          zoom: 14,
          slider: false
        map.on("layers-add-result", initEditor);
        //add boundaries and place names
        var labels = new ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer");
        map.addLayer(labels);
        var rivers = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/FeatureServer...",{
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ['*']
        var waterbodies = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/FeatureServer...",{
          outFields: ['*']
        map.addLayers([waterbodies,rivers]);
        waterbodies.on("edits-complete", function(results){
          console.log(results);
        function initEditor(evt) {
          var templateLayers = arrayUtils.map(evt.layers, function(result){
            return result.layer;
          var templatePicker = new TemplatePicker({
            featureLayers: templateLayers,
            grouping: true,
            rows: "auto",
            columns: 3
          }, "templateDiv");
          templatePicker.startup();
          var layers = arrayUtils.map(evt.layers, function(result) {
            return { featureLayer: result.layer };
          var settings = {
            map: map,
            templatePicker: templatePicker,
            layerInfos: layers,
            toolbarVisible: true,
            createOptions: {
              polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ],
              polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON,
                Editor.CREATE_TOOL_CIRCLE,
                Editor.CREATE_TOOL_TRIANGLE,
                Editor.CREATE_TOOL_RECTANGLE
            toolbarOptions: {
              reshapeVisible: true
          var params = {settings: settings};
          var myEditor = new Editor(params,'editorDiv');
          //define snapping options
          var symbol = new SimpleMarkerSymbol(
            SimpleMarkerSymbol.STYLE_CROSS,
            15,
            new SimpleLineSymbol(
              SimpleLineSymbol.STYLE_SOLID,
              new Color([255, 0, 0, 0.5]),
            null
          map.enableSnapping({
            snapPointSymbol: symbol,
            tolerance: 20,
            snapKey: keys.ALT
          myEditor.startup();
    </script>
  </head>
  <body class="claro">
    <div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;">
      <div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'">
        Edit Hydrography
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width: 300px;overflow:hidden;">
        <div id="templateDiv"></div>
        <div id="editorDiv"></div>
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" id="map" data-dojo-props="region:'center'"></div>
    </div>
  </body>
</html>
AzizaParveen2
Thanks so much Jake, I will try it and let you know☺
AzizaParveen2
Jake the sample didn’t work for me, since I was using editor widget, all I needed was to deactivate the toolbar,. Thanks so much for your time.
