Hello,
I have a Dynamic service in a map where im adding a definitionExpression for getting 1 result applied to 2 layers (the first one is point and the second one is lines).
What i want to achieve is doing a zoom into the feature that im showing with the definition expression on the map, but I dont know if there is a way to do this without doing a query for zooming (and getting the extent) of the polyline layer.
I know if i do a query in the points layer i can set the map zoom into that feature, but is this possible also with a polyline layer?
When i do a query in the polyline layer i have an array of results, so how can i set up the map extend to zoom in the area that i want?
Thanks in advice.
Evelyn,
You just use the executeForExtent method of the QueryTask.
