Display Attachement in Popup Template
3973
8
10-23-2022 10:48 PM
cadgism
Hi All Greetings
Trying to display the attachment image in Popup Template, but not able to display the full image . It shows only like a broken link image. But when clicked , it opens in new window and displaying like charm.
How can I display the full image it inside the popup , please
Thank you.
urlNaturalresourcesF = "https://xxxxxxxxxxx/arcgis/rest/services/WebQuery/ Naturalresources/MapServer/0";
 naturalServicepathF = new FeatureLayer(urlNaturalresourcesF, { id: "naturalRes", mode: FeatureLayer.MODE_ONDEMAND, outFields: ["*"], listMode: "hide" });
 //Attachment content
let attachmentsElement = new AttachmentsContent({
  displayType: "auto"
  //displayType: "preview"
let template = new PopupTemplate({
  title: "Natural Resources",
  outFields: ["*"],
  content: [attachmentsElement]
naturalServicepathF.popupTemplate = template;
//check crome if service is running without safe browse for https
map.add(naturalServicepathF);
JayakumarPD
See will this helps you.
https://developers.arcgis.com/javascript/latest/api-reference/esri-popup-content-ImageMediaInfo.html
// Create the ImageMediaInfoValue
let imageMediaInfoValue = new ImageMediaInfoValue({
  sourceURL: "<insert URL>"
let imageElement = new ImageMediaInfo({
  title: "<b>Mexican Fan Palm</b>",
  caption: "tree species",
  value: imageMediaInfoValue
// Create the MediaContent
let mediaElement = new MediaContent({
  mediaInfos: [ imageElement ]
JayakumarPD
cadgism
Thank you Jayakumar PD
This is an attachment,  how do I specify the source URL here
JayakumarPD
Is it possible to share the code.  I don't have any service layer with image.
cadgism
Sure,  Will publish a service and share
JayakumarPD
Done, then I will also try to figure it out, once you publish.
cadgism
Solved. This is how it works. Your reply was helpful to solve this issue.
function showAtts(event){
  view.hitTest(event).then(function getGraphics(response) {
    if (response.results.length) {
      graphic = response.results[0].graphic;
      console.log(graphic);
      lyrUrl = graphic.layer.url + "/0/";
      objID = graphic.getAttribute('RemarkPoint.OBJECTID');
      attID = graphic.getAttribute('RemarkPoint__ATTACH.ATTACHMENTID');
      imgUrlPath = lyrUrl+objID+"/attachments/"+attID;
          sourceURL: imgUrlPath
        caption: "Photo",
        outFields: ["*"],
        showAttachments: true,
        content: [mediaElement],
RobertKirkwood
I am still getting a broken picture. Can you show the rest of the code? I may be missing where getGraphics is being used.
My code is below
Thanks!
RobertKirkwood
<!DOCTYPE html>
<html lang="en">
<head>
  <meta charset="utf-8" />
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <link rel="shortcut icon" href="//uwoperations.uwyo.edu/uwopsmaps/Documents/Icons/favicon.ico" />
  <title>Query Attachments Buildings</title>
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    #attachmentsDiv {
      height: 100%;
      width: 30%;
      float: left;
      padding: 20px;
      overflow: auto;
      min-width: 240px;
    #viewDiv {
      height: 100%;
      max-width: 70%;
    .queryImg {
      width: 175px;
      padding-right: 5px;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.29/esri/themes/dark/main.css" />
  <link rel="stylesheet" href="css/allStyles.css">
  <script src="https://js.arcgis.com/4.29/"></script>
<!--  <script src="js/map.js"></script>
  <script src="js/baseQueries.js"></script>-->
  <script>
      require ([
    "esri/Map",
    "esri/views/MapView",
    "esri/layers/FeatureLayer",
    "esri/widgets/Legend",
    "esri/PopupTemplate",
    "esri/popup/content/AttachmentsContent",
    "esri/popup/content/support/ImageMediaInfoValue",
    "esri/popup/content/ImageMediaInfo",
    "esri/popup/content/MediaContent"
], function (
        Map, MapView, FeatureLayer, Legend, PopupTemplate, AttachmentsContent, ImageMediaInfoValue, ImageMediaInfo, MediaContent
    function showAtts (event)
        view.hitTest (event).then (function getGraphics (response)
                console.log (graphic);
                objID = graphic.getAttribute ('RemarkPoint.OBJECTID');
                attID = graphic.getAttribute ('RemarkPoint__ATTACH.ATTACHMENTID');
                imgUrlPath = lyrUrl + objID + "/attachments/" + attID;
                let imageMediaInfoValue = new ImageMediaInfoValue ({
                let imageElement = new ImageMediaInfo ({
                    title:  "{LONGNAME}",
                    caption: "Photo",
                let mediaElement = new MediaContent ({
                    mediaInfos: [imageElement]
                let template = new PopupTemplate ({
                    outFields: ["*"],
                layer.popupTemplate = template;
    // get layer from online portal
    const layer = new FeatureLayer ({
        url:
                "https://uwoperations.uwyo.edu/hostgis/rest/services/CampusMap/CampusMap_Buildings/FeatureServer/0",
        //popupTemplate: template,
        outFields: ["*"]
    // setup the map
    const map = new Map ({
        basemap: "topo-vector",
        layers: [layer]
    const view = new MapView ({
        container: "viewDiv",
        map: map,
        center: [-105.567, 41.313193],
        zoom: 16
    view.ui.add (new Legend ({view: view}), "bottom-left");
    let highlight;
    view.on ("click", function (event)
        clearMap ();
        queryFeatures (event);
        showAtts (event);
    function queryFeatures (screenPoint)
        const point = view.toMap (screenPoint);
        // Query the for the object ids within 800m from where the user clicked
        layer.queryObjectIds ({
            geometry: point,
            spatialRelationship: "intersects",
            distance: 10,
            units: "meters",
            returnGeometry: false,
            outFields: ["*"]
                .then (function (objectIds)
                    if (!objectIds.length) {
                        showMessage ();
                        return;
                    // Highlight the query-area on the map
                    view.whenLayerView (layer).then (function (layerView)
                        if (highlight) {
                            highlight.remove ();
                        highlight = layerView.highlight (objectIds);
                    // Query the for the attachments from the object ids found
                    return layer.queryAttachments ({
                        attachmentTypes: ["image/jpeg"],
                        objectIds: objectIds
                .then (function (attachmentsByFeatureId)
                    if (!attachmentsByFeatureId) {
                        return;
                    if (Object.keys (attachmentsByFeatureId).length === 0) {
                        const infoP = document.createElement ("p");
                        infoP.innerHTML = "<b>There are no building image/jpeg attachments located in your query area.</b>";
                        document.getElementById ("queryResults").appendChild (infoP);
                    // Display the attachments
                            .forEach (function (objectId)
                                const attachments = attachmentsByFeatureId[objectId];
                                attachments.forEach (function (attachment)
                                    const image = document.createElement ("img");
                                    image.src=attachment.url;
                                    image.className = "queryImg";
                                    document.getElementById ("queryResults").appendChild (image);
                .catch (function (error)
                    showMessage ();
    function showMessage ()
        clearMap ();
        infoP.innerHTML = "<b>There are no building image/jpeg attachments located in your query area. Please click within the feature layer to get results.</b>";
    // Clear attachments from div
    function clearMap ()
        if (highlight) {
        const att = document.getElementById ("queryResults");
        while (att.firstChild) {
            att.removeChild (att.firstChild);
  </script>
</head>
<body>
  <div id="attachmentsDiv" class="esri-widget">
    <h2 align="center"> <input id="LogoA" title="UW Website" type="image" alt="LogoA" src="Icons/UWWebA.png"
        onClick="javascript&colon; return popitup ('http://www.uwyo.edu/')" /></h2>
    <h2>Building Photos</h2>
    <p>Click somewhere in the map to query for images of trees located on a block within 800m of your desired location.
    </p>
    <div id="queryResults"></div>
  </div>
  <div id="viewDiv"></div>
</body>
</html>
Tags (1)
