DataGrid field update and styling
9587
32
10-17-2011 08:26 AM
SamirGambhir
I have two questions related to Dojox Data Grid:
1. I have an application where the datagrid has two columns. One column always displays unique names (e.g. state names) and the second column has to display indicator value for each state depending on which indicator is selected i.e. When user selects 'Population' from a dropdown select form, the second column displays its value. I would like this column to refresh its value when user makes another selection. The data grid examples on esri.com show hard-coded field name in the HTML markup. Is there a way to make the field name dynamic?
2. Is there a way to apply my own css style to the table (cells, borders, heading etc.)?
Thanks for your help,
Samir
LindaDunklee
I am having the same issue with this as Adam mentions above - my updated values don't persist when I redo the search.  My service is also enabled to allow editing and the value changes in the grid until the search is redone.  Checking the database, the value does not change.  Has anyone been able to resolve this issue?
thejuskambi
Hello Linda
The updateDataGrid.txt does not have any logic to update the server. i.e. no code is calling the featurelayer.applyedits method. the store.setValue updates only the memory variables so as long, you dont search again the values you have updated will remain. But if you get the records again from the service. The original values will be returned.
Hope this answers your doubt.
Thejus
LindaDunklee
Thanks thejus, this makes sense!  Forgive my ignorance - with the existing code above, what would be the easiest way to commit the edits to the server?
