Rajni,
To update a graphic using SketchViewModel, the graphic has to be in the same SpatialReference as the map. So in this case you use WebMercatorUtils to project the polygon to webmercator before you add it to the map.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
<title>Intro to MapView - Create a 2D map - 4.14</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.14/esri/themes/light/main.css" />
<script src="https://js.arcgis.com/4.14/"></script>
<script>
require(["esri/views/MapView",
"esri/WebMap",
"esri/Graphic",
"esri/layers/GraphicsLayer",
"esri/widgets/Sketch/SketchViewModel",
"esri/geometry/Polygon",
"esri/geometry/SpatialReference",
"esri/geometry/support/webMercatorUtils"
], function (MapView, WebMap, Graphic, GraphicsLayer, SketchViewModel, Polygon, SpatialReference, webMercatorUtils) {
let sketchViewModel,
validSymbol,
newDevelopmentGraphic;
var webmap = new WebMap({
portalItem: {
var view = new MapView({
map: webmap,
container: "viewDiv",
center: [175.9258624, -37.55590445],
zoom: 20
var graphicsLayer = new GraphicsLayer();
webmap.add(graphicsLayer);
setUpGraphicClickHandler();
view.when(function () {
addGraphics();
sketchViewModel = new SketchViewModel({
view: view,
layer: graphicsLayer,
updateOnGraphicClick: false,
defaultUpdateOptions: {
toggleToolOnClick: false
sketchViewModel.on(["update", "undo", "redo"], onGraphicUpdate);
function onGraphicUpdate(event) {
const graphic = event.graphics[0];
if (
event.toolEventInfo &&
(event.toolEventInfo.type === "move-stop" ||
event.toolEventInfo.type === "reshape-stop")
sketchViewModel.complete();
} else if (event.state === "cancel" || event.state === "complete") {
sketchViewModel.update([graphic], {
tool: "reshape"
function setUpGraphicClickHandler() {
view.on("click", function (event) {
if (sketchViewModel.state === "active") {
return;
view.hitTest(event).then(function (response) {
var results = response.results;
results.forEach(function (result) {
console.log(result.mapPoint);
if (
result.graphic.layer === sketchViewModel.layer &&
result.graphic.attributes &&
result.graphic.attributes.newDevelopment
sketchViewModel.update([result.graphic], {
tool: "reshape"
function addGraphics() {
const vertices = [
[175.9258630667, -37.55587745],
[175.9258671333, -37.5557153],
[175.92626316670004, -37.5557216],
[175.92625955, -37.5558657],
[175.9262584333, -37.5559107333],
const polygon = createGeometry(vertices);
validSymbol = createSymbol([0, 170, 255, 0.8], "solid", 2, [
255,
255,
255
newDevelopmentGraphic = new Graphic({
geometry: webMercatorUtils.geographicToWebMercator(polygon),
symbol: validSymbol,
attributes: {
newDevelopment: "new store"
graphicsLayer.add(newDevelopmentGraphic);
function createGeometry(vertices) {
return new Polygon({
rings: vertices,
spatialReference: new SpatialReference({
wkid: 4326
function createSymbol(color, style, width, outlineColor) {
return {
type: "simple-fill",
style: style,
color: color,
outline: {
color: outlineColor,
width: width
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
