Create extent to fit all points keeping centre fixed
4108
02-08-2019 08:01 AM
Rupam_RanjanRana
I'm trying to derive an extent out of a list of point geometries, so that all the geometries fit into the extent, keeping fixed to a provided centre. The problem I'm having with extent.union() is it, doesn't keep the extent centre fixed. And doing extent.centerAt() post all the union()s does not fit all the points. And extent.expand() does not take a point. Is there a similar solution as google.maps.LatLngBounds.extend(Point) in ARCGis to extend the extent to a given point keeping the centre fixed.
fitBounds: function (mapsterGeoJson, boundCen) {
        var me = this;
        var tempExtnt = null;
        var resExtnt = this.createPointExtent(boundCen.getValue());
        mapsterGeoJson.getVendorGeoJSON().graphics.forEach(function (graphics) {
            tempExtnt = me.createPointExtent(graphics.geometry);
            if (!resExtnt.contains(tempExtnt)) {
                resExtnt.union(tempExtnt);
        resExtnt.centerAt(boundCen.getValue());
        me.getVendorView().whenLayerView(mapsterGeoJson.getVendorGeoJSON()).then(
        function () {
            me.getVendorView().goTo(resExtnt);
        return this;
createPointExtent: function (pointGeometry) {
    return  new this.mapObj.apiInterface.geometry.Extent({
            xmin: pointGeometry.longitude,
            xmax: pointGeometry.longitude,
            ymin: pointGeometry.latitude,
            ymax: pointGeometry.latitude
RobertScheitlin__GISP
Rupam,
   I convert a point into an extent using a default 6 pixel tolerance. Normally I use this for getting an extent from a mouse click, but I think it will help in your situation.
pointToExtent: function (pointGeometry, distance) {
  var clickOffset = distance || 6;
  var centerPoint = pointGeometry.clone();
  var mapWidth = me.getVendorView().extent.width;
  var pixelWidth = mapWidth / me.getVendorView().width;
  var tolerance = clickOffset * pixelWidth;
  var queryExtent = new this.mapObj.apiInterface.geometry.Extent({xmin: 1, ymin: 1, xmax: tolerance, ymax: tolerance, spatialReference: pointGeometry.spatialReference});
  return queryExtent.centerAt(centerPoint);
Rupam,
  The one way I can think of is to clone the resExtnt to a new var before you center it. then union the centered resExtnt and the cloned one.
Rupam_RanjanRana
Robert,
Tried it, but doesn't work.
setBounds: function (mapsterGeoJson, boundCen) {
        var me = this;
        var clonedExtent = resExtnt.clone();
        resExtnt.union(clonedExtent);
        function () {
        return this;
Also couldn't use extent.expand() as it requires a factor to multiply and I have to test all the points after expand till all the points fit. And also the point extents have zero height and width so expand will not modify the extent at all.
Rupam,
Rupam_RanjanRana
Hi Robert,
The solution worked. So the code now looks as follows.
setBounds: function (mapsterGeoJson, singularity) {
        var me = this;
        me.getVendorView().whenLayerView(mapsterGeoJson.getVendorGeoJSON()).then(function () {
            var blackhole = me.createPointExtent(singularity.getValue()); //Create extent at the center
            var maxDist = 0, tempDist = 0;
                tempDist = me.mapObj.apiInterface.geometry.geometryEngine.distance(singularity.getValue(),
                    graphics.geometry);
                if (tempDist > maxDist) {
                    maxDist = tempDist;
            }); //Find the farthest distance from center
            /*Expand the extent to the farthest geometry. And acounting for device aspect ratio.*/
            blackhole.expand((maxDist + (maxDist * 1.5)) / blackhole.width);
            me.getVendorView().goTo(blackhole);
        return this;
        var clickOffset = 6;
        var mapWidth = this.getVendorView().extent.width;
        var pixelWidth = mapWidth / this.getVendorView().width;
            xmin: 1,
            ymin: 1,
            xmax: tolerance,
            ymax: tolerance,
Thank you for the help.
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
