Create a FeatureLayer with client-side graphics, attributes missing
1101
06-20-2019 01:46 PM
XiaowenHuang
I use the following sample to add a shapefile to FeatureLayer but attributes won't carry over.
ArcGIS API for JavaScript Sandbox
Any idea how I can retain all attributes from shapefile?
RobertScheitlin__GISP
You just need to specify the Feature Layers fields and outFields properties in that sample.
            var featureLayer = new FeatureLayer({
              popupTemplate: popupTemplate,
              objectIdField: "FID",
              source: graphics,
              outFields: ['*'],
              fields: layer.layerDefinition.fields
DavidWilson3
Hi Xiaowen,
Do you have screenshots or code you can share? Off the top of my head I would think that perhaps your shapefile is not a zip folder or your zip folder does not have all the necessary files in it to draw it with attributes.
              source: graphics,
              outFields: ['*'],
XiaowenHuang
Thanks! adding "fields: layer.layerDefinition.fields" solved the issue.
