CoordinateConversion Widget
1929
11-02-2020 10:49 PM
cadgism
Hi
   Can I customize the Coordinate Conversion Widget to display only  BASEMAP &  XY Coordinates and remove the rest from the default conversion options in 4.17
Thanks
RobertScheitlin__GISP
cadgis,
  Just add this css rule:
.esri-coordinate-conversion__select-row option[value="dd"],
[value="ddm"],[value="dms"],[value="mgrs"],[value="usng"]
,[value="utm"]{
  display: none;
cadgis,
,[value="utm"]{
  display: none;
rogenjh
How would you go about this if you were also removing XY? As I understand it, Display: None will not remove the element from the DOM, and so it will render at the first "selected" in the slot, and then only be removed when the user makes a selection.
