I am stuck how to convert lat,long to bbox using WGS-84. Is there a formula or function code you could share.
e.g. lon=-79.80617638166511
lat=43.17565342984143
bbox?
Raju,
My code snippet above is for a map click function where the event object passed is the map click event.
Here is a function to convert a lat lon to an extent.
function onSelDrawEnd(lat, lon) {
var mapPnt = new Point(parseFloat(lon), parseFloat(lat));
var scrPnt = map.toScreen(mapPnt);
//Expand the point by 5 pixels
var xMin = scrPnt .x - 2.5; //value in pixels
var yMin = scrPnt .y - 2.5; //value in pixels
var xMax = scrPnt .x + 2.5; //value in pixels
var yMax = scrPnt .y + 2.5; //value in pixels
var mp1 = map.toMap(new Point(xMin, yMin));
var mp2 = map.toMap(new Point(xMax, yMax));
var ext = new Extent(mp1.x, mp1.y, mp2.x, mp2.y, new SpatialReference({ wkid:4326 }));
return Polygon.fromExtent(ext);
Raju,
To get a bounding box from a single point you just need to do some math to add and subtract for that point to get the minx, miny, maxx and maxy for the extent class constructor.
Thanks Rob for always being helpful. I am using simple math to get bbox from lat,long. It is not accurate for closest zoom scale.
var minxx = lon - 0.08999;
var maxxx = lon + 0.08999;
var minyy = lat - 0.08999;
var maxyy = lat - 0.08999;
console.log("weblink/bbox?" + "xmin=" + minxx + "&ymin=" + minyy + "&xmax=" + maxxx + "&ymax=" + maxyy).
I have WGS-84 projection. Do I have to add condition for each scale. e.g.
If (scale =11)
elseif (scale =19)
var minxx = lon - ??;
var maxxx = lon + ??;
var minyy = lat - ??;
var maxyy = lat - ??;
Raju,
Normally I would be adding/subtracting values with a set number of pixels using toScreen and toMap.
Thanks Rob for your response. Could you kindly provide an example for set of pixels toScreen and toMap. I have a deadline to meet.
You working in 3.x or 4.x?
I am using 3.x. Thanks in advance for your help!
Raju,
Here is how I turn a point into a polygon to query by:
function onSelDrawEnd(event) {
var geom = event.mapPoint;
var xMin = event.screenPoint.x - 2.5; //value in pixels
var yMin = event.screenPoint.y - 2.5; //value in pixels
var xMax = event.screenPoint.x + 2.5; //value in pixels
var yMax = event.screenPoint.y + 2.5; //value in pixels
var ext = new Extent(mp1.x, mp1.y, mp2.x, mp2.y, geom.spatialReference);
var pPoly = Polygon.fromExtent(ext);
queryFeaturesGraphical(pPoly);
Thanks Robert for sharing "turn point into a polygon". Could you please guide how I can pass 'event' into my existing code (above code). Your help is appreciated.
Raju,
