How can I get the click on a polygon that was drawn using Sketch Widget? I tried hitTest, but it brings several results (points and polygons)
Currently my code looks like this:
view.on("click", function (event) { view.hitTest(event.screenPoint).then(function (response) { console.log(response.results); //results an array of geometrys }); });
Thafny,
Just loop through the hit test results and look at the response.results array (which is an array of graphics) Each graphic has a layer property. You check if the layer is the same layer id as your polygon layer that you are interested in.
Thafny,
Thanks!!!
