Change the Start Time Field in time aware layers
4584
03-30-2016 08:09 AM
IsraAlhamood
Hello everyone,
I implemented a simple map viewer for time aware layers. it has a time slider.
I'm trying to change the start time field to another date field in the map layer.
How can I do that?
Time Info:
    • Start Time Field: WB_SPUD_DT
      End Time Field: null
      Track ID Field:
      null
      Time Extent:
        [1935/01/01 00:00:00 UTC, 2016/01/01 00:00:00 UTC]
      Time Reference:
      N/A
      Time Interval: 5
      Time Interval Units: esriTimeUnitsYears
      Has
      Live Data: false
      Export Options:
        Use Time: true
      Time Data Cumulative: false
      Time Offset:
      null
(null)
RobertScheitlin__GISP
Isra,
  For that you will have to edit the actual mxd that the service is coming from.
Isra,
  Here is how to define the the start time:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
    <title></title>
    <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.16/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.16/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%; width: 100%; margin: 0; padding: 0;
      #loading {
        width:100%;
        position:absolute;
        height:400px;
        background:transparent url("https://dl.dropboxusercontent.com/u/2654618/ajax-gear.gif") center no-repeat;
        z-index:100;
    </style>
    <script src="//js.arcgis.com/3.16/"></script>
    <script>
      var map;
      require([
        "esri/map", "esri/InfoTemplate",
        "esri/layers/FeatureLayer",
        "dojo/parser", "dojo/dom-construct", "esri/TimeExtent",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
        "dojo/domReady!"
      ], function(
        Map, InfoTemplate,
        FeatureLayer,
        parser, domConstruct, TimeExtent
          parser.parse();
          map = new Map("mapDiv", {
            basemap: "oceans",
            center: [-100, 40],
            zoom: 4
          // feature service with U2 concerts from 1980 - 2011
          var featuresUrl = "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/U2/FeatureServer/0";
          var layer = new FeatureLayer(featuresUrl, {
            infoTemplate: new InfoTemplate(
              "U2 Concerts:  1980  2011",
              "Date:  ${Date:DateFormat(selector: 'date', fullYear: true)}<br>" +
              "Venue:  ${Venue}, ${City}, ${State}<br>" +
              "Tour:  ${Tour}"
            mode: FeatureLayer.MODE_SNAPSHOT,
            outFields: ["*"]
          console.info(layer.timeInfo);  //This one will be undefined.
          layer.setUseMapTime(true);
          var layerUpdateEnd = layer.on("update-end", function() {
            console.info(layer.timeInfo); //This one will have an actual value because the layer is loaded.
            layerUpdateEnd.remove();
            var timeExtent = new TimeExtent();
            timeExtent.startTime = new Date("1/1/1989 UTC");
            map.setTimeExtent(timeExtent);
            domConstruct.destroy("loading");
          map.addLayer(layer);
    </script>
  </head>
  <body class="tundra">
    <div class="demoLayout" style="height: 100%; width: 100%"
         data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design: 'headline'">
        <div class="centerPanel"
             data-dojo-type="dijit/layout/ContentPane"
             data-dojo-props="region: 'center'">
          <div id="mapDiv"
            data-dojo-props="region:'center'">
            <div id="loading"></div>
          </div>
        </div>
    </div>
  </body>
</html>
IsraAlhamood
But can I change the field itself
I meant this one
Can I change it to another Date type field? Or it's not possible?
Isra,
