I have tried using the below in my initial query, and query right before drawing my polygons with class breaks.
query.orderByFields = ["Shape__Area DESC"];
However this did not seem to do anything. I have also tried using grid_value field as well.
You can see in the screenshot a 3.8 grid value polygon overlapping making the inner 6.5 and 7.8 grid_value polygons in accessible to click.
Here is my relevant code in which I am querying and then doing the drawing... main problem is occasionally large polygons block out smaller ones.. I can mostly see them, but visibility is not the issue.. I need to be able to click them as well.. if the smaller polygons would draw on top most layer, or even higher grid values on top should solve it. I found orderByFields in the docs but doesn't seem to do anything at all...
query.outFields = ["*"];
query.returnDistinctValues = false;
query.returnGeometry = true;
QT.execute(query).then(function (evt) {
evt.features.forEach(function (feature) {
var att = feature.attributes
var test = geometryEngine.convexHull(feature.geometry)
var genpoly = null
if (att.grid_value <= 4.0) {
var rad = att.Shape__Length / 75
genpoly = new Circle({
center: test.centroid,
radius: rad,
radiusUnit: "meters"
} else {
genpoly = test
var polygonGraphic = new Graphic({
geometry: genpoly,
attributes: att,
type: "polygon"
gras.push(polygonGraphic);
var renderer = {
type: "class-breaks",
field: "grid_value",
classificationMethod: "esriClassifyManual",
classBreakInfos: [{
minValue: 0,
maxValue: 1.9999,
symbol: {
color: [0, 0, 0, 0],
outline: {
width: 0.4,
type: "simple-line",
style: "solid"
type: "simple-fill",
style: "solid"
label: "I (Not Felt)"
minValue: 2.0,
maxValue: 3.0,
symbol: {
color: [191, 204, 255, .3],
outline: {
width: 0.4,
style: "solid"
style: "solid"
label: "II (Weak)"
minValue: 3.1,
maxValue: 3.9,
symbol: {
color: [153, 153, 255, .4],
outline: {
width: 0.4,
style: "solid"
style: "solid"
label: "III (Weak)"
minValue: 4.0,
maxValue: 4.5,
symbol: {
color: [136, 255, 255, 1],
outline: {
width: 0.4,
style: "solid"
style: "solid"
label: "IV (Light)"
minValue: 4.5,
maxValue: 4.9999,
symbol: {
color: [125, 248, 148, 1],
outline: {
width: 0.4,
style: "solid"
style: "solid"
label: "V (Light)"
minValue: 6.0,
maxValue: 6.9999,
symbol: {
color: [255, 255, 0, 1],
outline: {
width: 0.4,
style: "solid"
style: "solid"
label: "VI (Strong)"
minValue: 7.0,
maxValue: 7.9999,
symbol: {
color: [255, 221, 0, 1],
outline: {
width: 0.4,
style: "solid"
style: "solid"
label: "VII (Very Strong)"
minValue: 8.0,
maxValue: 8.9999,
symbol: {
color: [255, 145, 0, 1],
outline: {
width: 0.4,
style: "solid"
style: "solid"
label: "VIII (Severe) "
minValue: 9.0,
maxValue: 9.9999,
symbol: {
color: [255, 0, 0, 1],
outline: {
width: 0.4,
style: "solid"
style: "solid"
label: "IX (Violent)"
minValue: 10.0,
maxValue: 10.9999,
symbol: {
color: [221, 0, 0, 1],
outline: {
width: 0.4,
style: "solid"
style: "solid"
label: "X"
minValue: 11.0,
maxValue: 11.9999,
symbol: {
color: [136, 0, 0, 1],
outline: {
width: 0.4,
style: "solid"
style: "solid"
label: "XI"
minValue: 12.0,
maxValue: 12.0,
symbol: {
color: [68, 0, 0, 1],
outline: {
width: 0.4,
style: "solid"
style: "solid"
label: "XII"
var popupTrails = {
outFields: ["*"],
"title": "Shake ID: {id}",
"content": function (feature){
let name_plc;
let dlv = document.createElement("div");
dlv.className = "popd";
dlv.innerHTML = `<b><span class='name_plc'></span></b><br>ID: <span class="ida">${feature.graphic.attributes.id}</span><br> URL: <a href="${feature.graphic.attributes.url}" target="_blank">View</a> <br> Updated: ${feature.graphic.attributes.updated} <br>Grid_value: ${feature.graphic.attributes.grid_value}<br> Event Time: ${feature.graphic.attributes.eventTime} <style>.esri-popup__navigation { display: none;}</style>`;
getName();
function getName() {
let cId = $('span.ida').text();
if (cId) {
let q3 = new Query();
q3.where = "id = '"+ cId +"'";
q3.outFields = ["*"];
QTt.execute(q3).then(function (results) {
results.features.map(function (feat) {
let pID = feat.attributes["id"];
if (cId === pID) {
name_plc = feat.attributes["place"];
console.log(name_plc);
let tx = $('.name_plc').text();
if (tx == 0){
$(".name_plc").append(name_plc);
} else {
setTimeout(getName, 230);
return dlv;
fl = new FeatureLayer({
source: gras,
objectIdField: "ObjectID",
geometryType: "polygon",
fields: [{
alias: "ObjectID",
type: "oid"
alias: "id",
type: "string"
alias: "Last Update",
type: "string"
alias: "eventTime",
type: "string"
alias: "url",
type: "string"
alias: "grid_value",
type: "double"
renderer: renderer,
popupEnabled: true,
popupTemplate: popupTrails,
visibleElements: [{
featureNavigation: false,
map.add(fl);
Here is my full CodePen as well.. Any way to do this client side javascript? simply change index to smallest polygons on top?! 1/3 times some of my polygons render in the correct order.. but I need to ensure they all always do, so they are visible and I can click them.
