arcgis javascript api 4 resize view.popup dynamically
2461
02-14-2020 06:01 AM
TomNicoski
I am looking to resize view.popup dynamically in ArcGIS Javascript API 4.x as was able to do in ArcGIS Javascript API 3.x using the map.infoWindow.resize(330,300);.  I have only found .esri-popup__main-container.esri-widget  in 4.x which can only be set once.
KellyHutchins
Esri Notable Contributor
One option might be to use the Feature widget to display the popup template content in a resizable container.
Feature | ArcGIS API for JavaScript 4.14
TomNicoski
Thanks, I will try.
